ᐅ How can I best install Ikea Metod cabinets under sloped ceilings?
Created on: 17 Feb 2020 10:02
SAUKEO
Hello everyone, I am currently planning a project to install Ikea Metod kitchen cabinets under a sloping ceiling and am looking for practical advice on the best way to approach this. The slope is quite steep, about 45 degrees, and I want to minimize space loss while avoiding unusual gaps or stability issues. I am especially interested in how to adjust the cabinets so they fit against the slope without the doors or drawers failing to open properly. Do you have experience adapting Metod units to angled walls, such as trimming the side panels or effectively using filler panels? Are there any tips for mounting the cabinets securely, considering the mounting surface is not completely flat? I am also grateful for recommendations on tools or special trim strips that might be helpful in this kind of installation. Thanks in advance!
plo60
18 Feb 2020 09:36
I would suggest asking a critical follow-up question here: How do you plan to handle the backs of the cabinets, which often do not sit flush against a sloped wall? Are you using spacers, or do you fill the gaps completely with trim panels?
Because a simple alignment against a sloped wall can lead to air gaps, which over time may cause issues with dust accumulation or instability.
Stating that the slope is about 45 degrees is not sufficient as a sole description—is the slope linear, or are there irregular shapes? With irregular profiles, it is usually less practical to make individual cutouts for each unit; a more modular adjustment approach is recommended.
ixlu1
19 Feb 2020 11:47
Hey, I find this topic really interesting! What helped me during installation was having a flexible system. A great experience was using adjustable feet for the cabinets – this allowed me to compensate for uneven floors. For the sloped ceiling, I placed thin strips as a buffer between the back of the cabinet and the roof slope. Then I simply cut the panels at an angle – in the end, it looks really professional!
So: go for it, it works great with a bit of patience and enjoyment of cutting!
lomin
19 Feb 2020 12:05
ixlu1 schrieb:
What helped me during installation was having a flexible system. Adjustable feet for the cabinets were a great experience – this allowed me to compensate for uneven flooring.
That sounds very helpful, especially with sloped ceilings where the floor often isn’t perfectly level either. How exactly did you connect the cabinets to ensure they remained stable despite the adjustable feet? Did you use any special connectors for that?
LAURE-TA
20 Feb 2020 08:15
SAUKEO schrieb:
How did you best determine the angles exactly when the slope isn’t completely regular? Do you use special tools or just a combined approach?
Very good question! In such cases, I usually combine several tools:
- First, I use a digital angle finder for a rough measurement of the roof slope.
- Then I create a cardboard template by holding it piece by piece against the slope and marking it with a pencil. This allows me to better adjust for unevenness or small deviations.
- If the cardboard template doesn’t fit precisely, I refine it further with a file or sandpaper until it fits perfectly.
The important thing is to work slowly and continuously check the fit, as cutting too early or too much can be critical.
chenfi
21 Feb 2020 14:34
SAUKEO schrieb:
Did you cut the side panels directly at the slope, or did you cut the side boards separately and then assemble them?
I usually cut the side parts first, before the cabinets are fully assembled. This way, I can work more precisely and have better control when fitting to the slope.
O
onan56
22 Feb 2020 09:12
I installed an Ikea Metod kitchen on a sloped ceiling myself last year and found the challenge exciting but sometimes frustrating. What helped me was patience and repeatedly testing the templates. It can be very frustrating if a door sticks or the cabinet isn't completely level. Important: Don’t get discouraged right away—instead, adjust step by step. And don’t let it put you off; it’s definitely possible, even if it takes more effort than working with straight walls.
