ᐅ How can I best install Ikea BESTA units as storage under a staircase?
Created on: 30 Jan 2021 08:33
tumau
Hello everyone, I want to create additional storage space under my staircase and have been considering an Ikea Besta system because it is modular and flexible. My staircase is wooden with quite a steep slope. The height under the stairs varies from about 70 cm (28 inches) at the lowest point to 120 cm (47 inches) at the highest point, with a depth of around 90 cm (35 inches).
My question is: What is the best and most effective way to adapt and install the Ikea Besta system to this stair slope so that it is stable, easily accessible, and makes the most efficient use of the space under the stairs? I am especially interested to know whether I should cut the Besta units to fit, whether additional reinforcements are worthwhile, or if a combination of drawers and doors is recommended. Does anyone have experience or tips on what I should definitely pay attention to? I want to avoid mistakes and minimize the need for rework.
JAMESONB41
31 Jan 2021 09:03
Cardboard is usually sufficient for the template. It is important that the original template fits perfectly. Then cut the panels to size using a jigsaw or circular saw. Whenever possible, secure them to the wall with screws and anchors. This ensures everything remains stable.
stefangla
1 Feb 2021 18:44
Hello everyone, I would like to take this opportunity to provide a step-by-step guide for installing Ikea Besta units under the stairs:
1. Precise measurement of the installation site: Measure height, depth, and width as accurately as possible and note the angled slopes.
2. Create a template: Cut cardboard or thin OSB boards as a model and place them on the outside to map the incline.
3. Planning the BESTA modules: Combine boxes, drawers, and doors in a way that best suits the use of the space.
4. Cutting: Ideally done by a professional or with appropriate tools. Accurate fitting is especially important for the tops and paneling.
5. Assembly of the base modules: Before final installation on site, roughly assemble and align the parts.
6. Fixing: Use wall fasteners with anchors to secure the construction against tipping. Additional reinforcements at connection points increase load capacity.
7. Finishing work: Paint or seal cut edges; adjust doors or drawer fronts if necessary.
Common mistakes are inaccurate measurements and missing wall fixings, which can cause problems in the long term.
If you have questions about any of the steps, I’m happy to help!
Ryder35
2 Feb 2021 10:11
When installing, make sure that the cabinets do not rest directly on the floor to prevent moisture. Small adjustable feet can help. I also recommend always attaching the back panel first before installing the doors.
Naomige
2 Feb 2021 12:29
I agree with the previous comments. I would like to add that when combining drawers and doors, the internal dimensions should be taken into account to prevent the drawers from hitting the sloped wall. It might also be worth considering the installation of internal guide rails or stops to ensure nothing gets stuck when opening. Additionally, choosing light-colored fronts is advisable, especially if the area under the stairs tends to be darker.
