ᐅ How can I best clean Ikea Hemnes furniture in homes with pets?
Created on: 24 Oct 2023 08:37
dannevin
dannevin
24 Oct 2023 08:37
I have a small question regarding the cleaning of my Ikea Hemnes furniture in a household with pets (especially cats and dogs). Since this furniture is made of solid wood and partly has lacquered surfaces, I am wondering: What is the best way to clean Ikea Hemnes in a pet household to gently remove pet hair and typical dirt (such as scratches and small stains) without damaging the surface or wearing down the protective layer? Are there any special cleaning products, home remedies, or methods that have proven effective? I would appreciate detailed tips that are also suited to the type of wood and practical for everyday use.
Ryder35
24 Oct 2023 09:11
I recommend first removing pet hair with a soft dust cloth or microfiber cloth. Then, wipe down with a slightly damp cloth. For stains, a mild soapy solution works well, but use it very sparingly.
mauka
24 Oct 2023 10:09
Pet hair and Hemnes furniture? That can be a bit of a challenge, but don’t worry! 🐾 My tip: Use a vacuum cleaner with an upholstery tool for the hair, followed by a slightly damp microfiber cloth. For light stains, I like to use a mix of warm water and a small amount of dish soap—apply gently, don’t rub, and your furniture will thank you! If you have a protective coating on the wood, avoid harsh cleaners, as they can quickly damage the finish.
barle
24 Oct 2023 12:27
mauka schrieb:
Vacuum cleaner with an upholstery nozzle for the hair, then a slightly damp microfiber cloth.
That works well. I would add: For scratches, gently sand with fine sandpaper and then apply wood oil. It is gentler than harsh cleaners.
dannevin
25 Oct 2023 07:52
Ryder35 schrieb:
A mild soap solution works well for stains, but use it very sparingly.
Thanks for the tip! May I ask if the soap solution is fully suitable for painted surfaces on Hemnes furniture, or should I use special products? In stores, there are often wood care products with nourishing ingredients—are these useful, or could they cause problems if you have pets?
KNUTGI
25 Oct 2023 09:30
A great tip that is often overlooked: When cleaning in homes with pets, avoid products containing ammonia or strong solvents – these can damage the finish and are also harmful to cats and dogs.
- First, vacuum or wipe off dust and hair
- Then clean lightly damp with a mild wood cleaner or diluted all-purpose cleaner
- Afterward, apply wood care oil or wax, but only if the furniture is untreated
For painted surfaces, it’s better to clean gently without re-oiling. This protects the wood finish and helps prevent allergic reactions in pets.
