ᐅ How can I neatly and safely integrate power strips into IKEA Besta units?
Created on: 15 Nov 2022 08:23
pemomarI am currently planning to integrate power strips neatly and safely into my IKEA Besta furniture to connect multiple electronic devices centrally. My specific question is: What options are there for installing these power strips in a way that keeps them visually discreet, practically accessible, and most importantly, free from electrical hazards? I am especially interested in the best ways to organize the cables neatly and whether there are appropriate mounts or drilling techniques for the Besta furniture to secure the strips safely. Additionally, I would like to know if there are any special requirements for the power strips themselves to ensure everything complies with safety standards. Tips on planning, installation, and avoiding common mistakes would be very helpful.
[@pemomar] Integrating power strips into IKEA Besta furniture truly requires careful planning, especially when both safety and aesthetics are important. My recommendation is to first measure precisely where the power strips will be placed so that access to the outlets is always ensured without cables being visible.
A common mistake is improper drilling: The back panel of Besta is often made of thin particle board, which can easily chip. It’s best to use a sharp wood drill bit and drill slowly to avoid damaging the surface. Before drilling, make sure there is enough space behind the back panel so that no cables can get pinched or damaged.
For securing the power strip, using mounting adhesive tape like double-sided foam tape combined with screws is recommended to achieve a stable attachment. Also, ensure that the power strip has built-in child safety features and surge protection if sensitive devices will be connected.
For cable management: adhesive cable ducts, cable ties, and cable clips are ideal. It’s important that cables are not kinked and that strain relief is provided so the power strip cannot be accidentally pulled out of its holder.
Regarding the choice of power strip: There are flat versions with mounting rails specifically designed for furniture applications. Alternatively, a standard power strip can be used with custom plastic brackets, which can be made or 3D-printed if available.
Have you already decided if the power strip needs to be rated sufficiently for devices like a TV, amplifier, lamp, etc.? This is important when selecting the strip.
Great topic! I have similar furniture and secured my power strips with small screws, neatly bundling the cables with cable ties. Always make sure the strip has enough clearance from the wall to prevent overheating. Safety is the number one priority! You can do it – just a little patience, and everything will look perfect!
For additional clarification:
- IKEA Besta furniture can have different back panels depending on the model (usually 3-4 mm (0.1-0.2 inch) particleboard). Before drilling, always check whether the back panel is strong enough to support mounting the power strip.
- Follow the recommended furniture depth to ensure sufficient clearance between the power strip and the surface, preventing overheating.
- Cable management: Plastic cable channels with a clamping mechanism allow tool-free routing and provide stable support.
- Power strips should have at least a CE marking and comply with local standards (e.g., VDE in Germany).
This ensures both functional safety and aesthetics.
Genevieve16 Nov 2022 10:15kibutar schrieb:
For secure installation, it is recommended to use mounting adhesive tapes such as double-sided foam tape combined with screws to achieve a stable fixture.I view this critically. Adhesive tapes can lose their hold over time, posing a risk, especially when installed inside furniture where access is limited. I generally recommend using purely mechanical fasteners (screws, brackets) to ensure long-term durability.
usbla schrieb:
Power strips should at least have a CE marking and comply with local standards (e.g., VDE in Germany).I completely agree. People often cut corners on quality, which backfires. Especially in furniture, cheap power strips should be avoided.
Does anyone have experience with specific furniture power strip systems or retrofit kits that are easy to install and safe? I would also like to include price in the discussion.
