ᐅ How do I install Ikea Metod cabinet doors with soft-close hinges?
Created on: 6 Apr 2019 08:37
Benka
Hello everyone, I am currently working on installing Ikea Metod kitchen doors with soft-close functionality. My specific question is: What are the step-by-step instructions for properly attaching the doors, correctly aligning the hinges, and optimally adjusting the soft-close mechanism? I already have basic knowledge of the Metod cabinets, but I am not familiar with the soft-close feature. Are there any particular details I should be aware of to ensure the doors close smoothly and do not stick? It would also be helpful to know which tools and aids are truly necessary. Thanks for your support!
bujufa
6 Apr 2019 11:02
I would like to add a tip regarding the soft-close feature: The damping system is very sensitive to the correct installation of the hinges. If the door is not flush or hangs unevenly, the damper can be subjected to excessive strain, which may cause noise or reduce its lifespan.
I also recommend carefully checking the door stop during installation. Metod hinges often allow a slight limitation of the opening angle, which can help the soft-close function work more effectively.
And: Always double-check that all screws are securely tightened during the final assembly, including after a few days of use.
Benka
6 Apr 2019 16:47
One last question for today: Are there different versions of the Ikea Metod soft-close hinges (for example, for different door thicknesses or opening angles) that should be considered, or are the installed parts universally compatible? I have standard doors with a thickness of 18 mm (0.7 inches), but the instructions do not always explicitly mention the hinge or soft-close variant.
Lyndon55
7 Apr 2019 07:15
Yes, there are different versions of Metod hinges, including soft-close options. They are generally designed for standard doors with thicknesses from 18 to 22 mm (0.7 to 0.9 inches).
For specialty doors (e.g., thicker panels or glass fronts), Ikea often uses slightly modified hinges. The soft-close dampers are also available in two versions: one for regular doors and one for door thicknesses with inserts.
The most important thing is to check the mounting position on the cabinet body (the dowel holes). If you have the original Ikea parts, the difference should not be significant for standard doors.
My tip: Make sure the hinges fit cleanly into the holes and do not force them in. Otherwise, the soft-close mechanism may be damaged.
taudi
7 Apr 2019 09:48
Lyndon55 schrieb:
For special doors (e.g., thicker fronts or glass fronts), Ikea often uses slightly modified hinges.
That’s exactly right. However, for standard Metod doors, the installation steps are the same for all soft-close hinges.
Here’s a brief summary to finish:
- Screw the hinges to the door
- Partially attach them to the cabinet and insert the door
- Adjust using the three screws (height, width, depth)
- Check the soft-close damper and ensure it clicks into place if needed
- Tighten the screws, but do not overtighten
- Remember to readjust after a few days to extend the lifespan
This should make your Metod kitchen door close smoothly and quietly. Good luck!
