ᐅ How do I install Ikea Metod cabinet doors with soft-close hinges?
Created on: 6 Apr 2019 08:37
Benka
Benka
6 Apr 2019 08:37
Hello everyone, I am currently working on installing Ikea Metod kitchen doors with soft-close functionality. My specific question is: What are the step-by-step instructions for properly attaching the doors, correctly aligning the hinges, and optimally adjusting the soft-close mechanism? I already have basic knowledge of the Metod cabinets, but I am not familiar with the soft-close feature. Are there any particular details I should be aware of to ensure the doors close smoothly and do not stick? It would also be helpful to know which tools and aids are truly necessary. Thanks for your support!
jokau
6 Apr 2019 08:51
The installation of the Metod doors with soft-close starts with fitting the hinges. Screw the hinges firmly onto the frame, then attach the door. After that, you can use the adjustment screws to align the door. To adjust the soft-close mechanism, usually a slight turn of the damper is enough.
taudi
6 Apr 2019 09:20
As an additional note: When installing the Metod doors with soft-close, I recommend the following procedure:
- First, pre-drill and screw the hinges onto the door if they are not already pre-assembled.
- Clamp the door to the cabinet body and adjust it in three dimensions using the adjustment screws (up/down, sideways, gap).
- The soft-close damper is usually pre-installed; check that it is properly engaged.
- To fine-tune the soft-close, you can sometimes adjust the angle or, with Ikea hinges, operate a small lever that activates/deactivates the damper.
A common mistake is that the hinges are not tightened enough or the screws are too loose, which causes binding or noise. Also, using suitable screwdrivers or a cordless drill with a fine-adjustment function is helpful.
If the doors do not close smoothly, simply readjust their alignment with the screws – it’s more of a fine-tuning process than a rigid installation.
Klakar
6 Apr 2019 09:36
Soft-close hinges are always located behind the door. Align the door and secure the hinges with 2 screws. Important: The soft-close mechanism must be engaged. Tools: Phillips screwdriver, possibly a cordless drill. Everything else involves fine adjustments to the hinge.
Benka
6 Apr 2019 10:05
Thanks for the quick tips! One more question: The soft-close elements on the hinges are already installed, but sometimes I feel like the door isn’t sitting perfectly straight and occasionally hangs slightly up or down. Is there a recommended sequence for tightening the screws to allow for later adjustments? I don’t want to fix them too early and then be unable to make corrections.
O
onron
6 Apr 2019 10:29
That is a good observation. Generally, it is advisable to loosely fasten the hinges first so the door still has some play for alignment. Then, you should first secure the screw for the horizontal adjustment, followed by the vertical adjustment, and finally adjust the depth.
The soft-close damper usually does not affect the alignment but only the closing action. It is important that after the initial installation, you gradually tighten all screws step by step, making adjustments as you go instead of tightening everything fully right away.
This way, you avoid misalignments and incorrect positioning.
