ᐅ How do I install Ikea Metod cabinets with soft-close drawers?
Created on: 22 Sep 2022 18:37
Miadnan
Miadnan
22 Sep 2022 18:37
I am currently working on installing several Ikea Metod kitchen cabinets with soft-close drawers at my home. I especially want to know how to correctly install and adjust the soft-close function on the drawers so that they close smoothly and quietly. Although I have the Ikea instructions, I find some parts a bit unclear, particularly when it comes to fine-tuning the drawers.
Could someone explain which steps are most important for a technically precise installation of the drawers? For example: In which order should the drawers be assembled and adjusted? Are there any tips on avoiding mistakes or resolving common issues?
Also, I am interested to know if any special tools are needed for the installation, or if a basic cordless drill is sufficient.
I look forward to helpful and practical advice from you that goes beyond the standard manual. Thank you in advance!
Tommy38
22 Sep 2022 19:09
Hello Miadnan,
I’m happy to help you with a detailed step-by-step guide to simplify the installation of the Metod cabinets with soft-close drawers. In general, you should proceed as follows:
- First, assemble the cabinet carcasses according to the instructions and secure them firmly. Pay special attention to ensure everything is square and stable; otherwise, the drawer may stick later.
- Next, install the drawer slides inside the cabinet carcass exactly according to the measurements in the instructions. This is important because the slides must be perfectly parallel and positioned at the correct height for the soft-close function to work properly.
- Now assemble the drawers, attach the slides to the sides, and insert them into the carcasses. The soft-close mechanism is usually integrated into the drawer slides.
- Fine adjustment is done using small screws on the drawers, which allow you to adjust the height, depth, and lateral spacing. This lets you perfectly align the drawer so it closes smoothly and quietly.
It is important to test after the initial contact of the soft-close function whether the drawer closes too hard or too softly and adjust if necessary. A regular cordless screwdriver with a Phillips bit is sufficient, but it’s better not to use overly powerful drivers to avoid damaging the material.
If you want, I can also share some common pitfalls and their solutions.
Good luck!
lubla
22 Sep 2022 20:18
Let me briefly summarize:
- Build the cabinet, making sure it is upright and level.
- Install the rails precisely parallel.
- Insert the drawers and adjust them using the screws on the side.
Soft-close works best when the rails are properly fitted and nothing is stuck. A cordless screwdriver is completely sufficient.
Can you specify exactly where the instructions are unclear for you?
MUMENAR
23 Sep 2022 08:27
lubla schrieb:
Can you specify exactly which part of the instructions is unclear for you?
That’s a good question, since IKEA instructions are often quite basic and assume a certain level of user experience.
I would critically examine the soft-close mechanism: Is the adjustment really only done via screws? Sometimes clamping mechanisms or spring tension are used, which are not explained in detail in the instructions.
Tommy38 schrieb:
The fine adjustment is made using small screws on the drawer, which allow you to adjust the height, depth, and lateral clearance.
Exactly – but how precise are these adjustment options really? Are there any practical experiences on how much leeway you have before the soft-close function is affected?
Also: Isn’t it important to consider how the load from the drawer and its usage impact the mechanism? I suspect that the materials of the slides may wear out quickly if the drawers are not installed perfectly parallel.
Therefore, my recommendation: When assembling, definitely use a spirit level and test the function under various loads after completing the build, not just with an empty drawer. Otherwise, you may later experience unexplained noises or functional issues.
What’s your view on this, Miadnan? Do you prioritize long-term precision fit, or is ease of installation more important to you?
