ᐅ How can I improve access to IKEA Metod corner cabinets?
Created on: 27 Sep 2015 08:23
leifle
I am currently working on improving the accessibility of IKEA Metod corner cabinets in the kitchen. My goal is to find ways to make accessing the often somewhat hard-to-reach corner areas of these cabinets easier and more ergonomic. Specifically, I am interested in which solutions are the most practical, which can be implemented with relatively little effort, and what limitations or special considerations I should be aware of for the different corner cabinet types (e.g., with hinged doors, carousel systems, or pull-out units).
Who has experience with methods to make access to the cabinet interior more efficient? Are there any special extensions, alternative interior layouts, or installation tips that can improve accessibility? I look forward to an active exchange with as many specific suggestions and proven solutions as possible.
Thanks in advance!
parpeo
28 Sep 2015 07:34
Hello leifle,
I think it’s great that you’re putting so much thought into optimizing accessibility in these corners. Corners are often underestimated as storage spaces, but you really have to use them cleverly.
leifle schrieb:
Would you recommend such a combination as a supplement to carousel shelves, or rather one or the other?
From my experience, it’s usually better to choose one system that covers the entire corner space, because mixed systems often interfere with each other or become confusing. However, narrow pull-outs on adjacent cabinets can be a helpful addition.
Additionally, I would recommend investing in high-quality fittings and slides, as these make handling much smoother, especially when pulling out or rotating.
Regarding stability: reinforcements inside the cabinet carcass, such as extra cross braces or angle brackets, provide more robustness without having to resort to expensive complete solutions.
I hope this helps you move forward a bit.
fodeo
28 Sep 2015 09:01
A very clear statement: install a carousel base, build it solidly, and that's it. Anything else just makes the process more complicated and expensive.
emmaju
28 Sep 2015 09:45
to summarize the posts and add some further comments, I would like to add the following:
The choice of system strongly depends on the available cabinet size and user behavior. Carousel units offer a lot of storage and easy access, but they can sometimes be more expensive and require a bit more space when opened.
Swing doors with pull-outs, on the other hand, are more space-saving but can be somewhat more complicated to install and are not as smooth to operate as carousels.
A combination of different solutions is possible, but only if the cabinet construction and dimensions fit. Careful planning is necessary to ensure that no mechanisms block each other and that all accesses work smoothly.
Regarding stability: IKEA cabinets gain a solid base through shelves, reinforcements, and assembly tips. Those carrying heavier loads should consider additional reinforcements, such as metal brackets or extra strips, without altering the cabinet frame itself.
My recommendation: run through your planning before purchase, use the IKEA planner if in doubt, and see which solution fits best. Sometimes visiting a showroom is also helpful.
I hope this helps you all!
