ᐅ How can I gently clean Malm surfaces?
Created on: 24 Dec 2020 08:17
Edwin
Edwin
24 Dec 2020 08:17
Good morning everyone, I have recently been looking into the care of the Malm furniture from IKEA and am wondering how to clean the surfaces gently without dulling the finish or causing discoloration.
Specifically: Which cleaning products and methods are recommended for the typical white lacquered surface of the Malm dresser, which seems to be some kind of melamine or lacquer coating?
It is important to me that no harsh chemicals or abrasive cleaners are used that could damage the surface. I am also interested in tips on how to best remove everyday dirt such as fingerprints, minor scratches, or dust so that the furniture stays looking good for a long time and the smooth surface is maintained.
How do you approach gentle cleaning, and what experiences have you had with the long-term effects of different products? Thanks in advance for your advice!
Kukar
24 Dec 2020 10:21
Hello Edwin, just use a soft, slightly damp microfiber cloth.
Only mild dish soap in water, no scrubbing or abrasive cleaners. Wipe again with a dry cloth. This keeps the surface intact.
Joshbe
24 Dec 2020 14:03
Edwin, to answer your question: The surfaces of Malm furniture are usually made of an MDF board with a foil-coated or painted finish. For cleaning, a soft cloth with lukewarm water and a few drops of a mild, pH-neutral cleaner, such as a gentle dish soap, is best.
It is important to avoid harsh substances like ammonia, alcohol, solvents, or abrasive agents, as these can damage the paint or foil.
Fingerprints can usually be wiped off easily with a damp cloth. For minor scratches, you can try polish products specifically designed for painted surfaces, but be cautious because not all products are suitable for melamine or foil finishes.
Dust should be removed regularly using a dry microfiber cloth to prevent abrasion. Long-term care depends heavily on using mild cleaning agents – it is better to clean gently and frequently than rarely and harshly.
Genevieve
24 Dec 2020 16:47
I always wonder how reliable such recommendations really are.
Joshbe schrieb:
For cleaning, a soft cloth with lukewarm water and a few drops of a mild, pH-neutral cleaner is best
This is generally true, but how exactly is "mild" defined in this context? Many pH-neutral cleaners contain additives that can damage the sealant over time.
Additionally, it would be interesting to know if there are studies or long-term tests proving that melamine surfaces are truly as sensitive as often claimed – or if some manufacturers are just being overly cautious to avoid warranty issues.
Does anyone have reliable sources on this or perhaps experience that confirms or contradicts it?
Also: What are your thoughts on household remedies like vinegar water or baking soda paste? My opinion is skeptical, as these can potentially cause damage.
Edwin
25 Dec 2020 09:12
A valid question. For me, it’s also important to know whether you should rely solely on the manufacturer’s instructions or if there are tried-and-tested household methods that work without risks.
Joshbe schrieb:
It’s important to avoid aggressive substances like ammonia, alcohol, solvents, or abrasive cleaners
– that sounds reasonable. I was wondering if it might be possible to use special furniture care wipes or sealing products to protect the surface.
Are there any recommendations for this, or is it generally unnecessary or even contraindicated on these surfaces? And what about everyday small scratches—as mentioned before, a polish seems like a good idea, but most polishes are designed for wood or lacquered solid wood.
Does anyone have specific product recommendations or experience with special care for Malm?
