Hello everyone, I have been having a problem with my IKEA Hemnes bed for some time. It squeaks quite loudly and annoyingly, especially when I move or turn over. I suspect the issue might be with the fastenings or the slatted bed base, but I'm not sure how to approach this systematically.
I have already tried tightening all the screws, but this only helped to a limited extent. Are there any proven methods or special tips to permanently eliminate these squeaking noises? Maybe someone has experience with the Hemnes bed frame and can offer advice on what to pay attention to?
I would really appreciate detailed feedback, ideally with step-by-step suggestions. Thanks!
Garth49 schrieb:
A great tip: Simply treat the connection points with a drop of wax or special furniture polish.This is a common trick, but be careful: Not every wax or polish is permanently effective or may even cause stains.
I would recommend first checking if wood or metal parts are rubbing against each other, and then applying a high-quality lubricant that does not harden or become sticky specifically in those areas. A Teflon spray can sometimes also help.
To effectively eliminate squeaking noises in IKEA Hemnes beds, I recommend a multi-step approach:
- Systematically check and tighten screws and bolts, using the appropriate tools rather than relying on visual estimation alone.
- Wooden contact surfaces can be lightly sanded with fine sandpaper if wood chips or unevenness are causing loud friction noises.
- Thin felt strips or foam rubber can be glued between the support points of the slatted frames to reduce friction.
- If necessary, treat wooden joints with a dry lubricant. I prefer specialized furniture waxes, as they do not leave a sticky residue.
Combining these measures usually provides a long-lasting solution.
olivernu schrieb:
Thin felt strips or foam rubber can be glued between the support points of the slatted frames to reduce friction.That sounds very interesting, thank you!
I wonder if using these felt strips affects the stability or functionality of the slatted frame?
Or are the felt strips designed to be thin enough so they only act as a buffer without changing the surface area?
Also, it would be helpful to know whether the felt strips should be applied to multiple support points or just individual ones.
