I recently assembled an Ikea Hemnes wardrobe and noticed that one of the doors is misaligned. The issue is that the door rubs slightly against the frame at the bottom and does not sit flush with the wardrobe. I suspect the hinges or the door installation might not be perfectly accurate, although I followed the assembly instructions precisely.
My question is: What is the best way to fix or adjust a misaligned door on Ikea Hemnes wardrobes? Is there anything specific to keep in mind, such as a recommended order for adjusting the hinges or particular tools needed for this?
I would greatly appreciate a detailed explanation or tips on how to resolve this problem permanently, as I’d rather not remove the entire door without knowing the correct procedure.
Thanks in advance!
Thanks in advance!
Hello jujopu,
I’m happy to help you here. Ikea Hemnes cabinets usually have doors equipped with concealed metal hinges that can be adjusted in three directions. This is great because it allows you to fix minor alignment issues very effectively.
Here is a step-by-step guide:
- First, you will usually find a small adjustment screw on the side of the hinge that allows you to move the door horizontally. This lets you shift it left or right.
- A second screw enables you to adjust the door vertically, meaning up or down, but only by a small amount.
- A third screw controls the gap between the door and the cabinet frame, adjusting how close the door sits.
It’s important to align the door first, then adjust all hinges evenly, and always use light torque to avoid overtightening the screws. If the door rubs, also check if the cabinet is standing on a level surface—sometimes the entire unit shifts due to an uneven floor.
Tools needed: a small Phillips screwdriver and possibly an Allen key, depending on the hinge.
If you’re unsure, take your time and make only small adjustments to each screw at a time. This way you get the best result and avoid damage.
Good luck!
Good luck!
draFrederi21 Feb 2023 17:48naujon schrieb:
Ikea Hemnes cabinets usually have doors equipped with concealed metal hinges that allow adjustment in three directions.Exactly, that’s really convenient! 😊 Especially with Hemnes, it’s worth being patient because those small screws that naujon mentioned are the real heroes when it comes to alignment.
I once accidentally slightly bent a door and initially thought it was broken. After a bit of screwing and adjusting, the door hung perfectly again.
A little tip from me: lift the door slightly when turning the vertical screw – this makes adjustment easier and helps you feel how the door moves.
Oh, and if the floor is uneven, the cabinet can stand “crooked” and cause additional door problems. A few furniture pads or felt glides under the cabinet feet can work wonders.
Good luck and don’t lose heart!
jujopu schrieb:
What is the best way to fix or adjust a misaligned door on Ikea Hemnes cabinets?In short: Loosen the screws on the hinge, align the door, then tighten the screws. Adjust horizontally, vertically, and in depth. Check the floor. Done.
