ᐅ How can I cost-effectively convert IKEA Besta units into a kitchen workstation with a countertop?
Created on: 8 May 2016 19:23
krzysztofu
krzysztofu
8 May 2016 19:23
I am currently planning to create a kitchen workstation with a countertop using IKEA Besta units. It is important for me to keep the project as cost-effective as possible without compromising too much on quality and functionality. My main goal is to provide storage space for kitchen utensils and a sturdy work surface for cutting and food preparation.
Has anyone had experience repurposing Besta modules to build a practical kitchen station? I am especially interested in tips regarding the countertop installation, the stability of the unit, and how to cleverly integrate cables or cooktop connections. Are there any recommendations for affordable accessories or complementary materials I should consider?
I look forward to your suggestions and experiences!
PRA64
9 May 2016 08:17
Hello krzysztofu,
First of all, using IKEA Besta as a base for a kitchen station is a good plan. The advantages are obvious: you get simple, affordable modules with flexible sizes and minimal assembly effort.
Here is my personal approach in small steps:
- Selection of base modules: Choose suitable Besta cabinets, possibly lower or higher depending on the desired working height (standard kitchen countertop height is 90 cm (35 inches)).
- Worktop: IKEA offers affordable worktops, often made of wood or laminate. Alternatively, you can get inexpensive cut-to-size pieces from a hardware store, which you can adjust in length and width.
- Stability: To make the whole setup sturdy, attach support beams or angle profiles to the back of the modules. Especially for longer worktops, reinforcement helps prevent sagging.
- Fixing: Be sure to screw the worktop securely to the base units. For fastening systems like those from Montana or similar, use screws with larger washers to prevent slipping.
- Cable management: If you want to integrate a stove or electrical appliances, drill discreet openings in the back panel or worktop and use cable channels.
- Accessories: IKEA often offers practical inserts for Besta, such as drawers or boxes. These increase functionality but are, of course, an additional cost—you can look for second-hand options or affordable add-ons here.
Common mistakes include using a worktop that is too thin without reinforcement and failing to secure the modules to each other, which can cause wobbling under load.
If you consider the weight of the worktop and appliances and properly connect the modules, you will get an inexpensive and practical kitchen station with Besta.
If you want, I can also provide tips on selecting tools and materials. Good luck!
kloreo
9 May 2016 10:41
Having the countertop cut from OSB or plywood is inexpensive and durable.
Connect the Besta frame securely using screws and brackets.
Drill a cable hole through the back panel and use simple cable channels from the hardware store.
PRA64
10 May 2016 16:57
kloreo schrieb:
Have a countertop cut from OSB or plywood, it’s inexpensive and durable.
Exactly, OSB is an affordable alternative because it is very strong and somewhat more flexible than laminate boards. However, if you expect moisture in the kitchen, you should properly seal OSB or better use plywood, which has a smoother surface and is more water-resistant.
kloreo schrieb:
Connect the Besta base frame securely using screws and metal brackets.
Attaching metal brackets on the inside is one of the best measures. It helps to join the modules into a single unit and prevents wobbling under load.
One more tip specifically for the countertop:
- Make sure to fix the countertop centrally with enough screws. Especially with longer boards, this avoids stress and warping.
- If your budget allows, choose a 25 mm (1 inch) thick board; thinner ones can warp more easily.
Regarding cable management, you will hardly find a good solution that requires no post-processing. A small opening in the cabinet at an inconspicuous spot, combined with cable channels, creates order and safety.
From my experience, such a kitchen setup with Besta is quite stable and practical for hobby use, as long as you pay attention to the small details during installation.
