ᐅ How can I combine PLATSA with other IKEA series?
Created on: 6 May 2019 19:27
nauje
nauje
6 May 2019 19:27
Hello everyone, I recently came across the PLATSA system from Ikea and find the wide range of customization options really interesting. However, I have a fairly detailed question: How can I effectively combine PLATSA with other Ikea series to create a harmonious overall look—both in terms of design and functionality? I’m especially interested in how PLATSA can be integrated with series like BESTÅ or KALLAX when designing different areas of a room or adding extra storage solutions.
I am familiar with the basic dimensions and materials of PLATSA and know that it is modular, but I find it challenging when it comes to colors and various connection options. Are there any proven combinations that work well together, or what should I definitely consider to avoid mismatched transitions or inconsistent appearances?
Looking forward to your experiences and advice!
tutan
6 May 2019 20:41
nauje schrieb:
How can I effectively combine PLATSA with other Ikea series to create a harmonious overall look – both in terms of design and functionality? I’m especially interested in how PLATSA can be combined with series like BESTÅ or KALLAX when designing different areas of a room or creating additional storage solutions.
Hey, that’s a really good question! 🙂 My tip is that PLATSA works really well with BESTÅ due to its modular flexibility, as both systems blend nicely with neutral tones like white or oak. It’s especially great if you want to alternate between closed and open units – they complement each other perfectly.
For KALLAX, I’d suggest creating contrast – for example, using PLATSA in a subtle wood finish and KALLAX in white, or vice versa. This way, you visually separate the areas, which works really well in open-plan spaces.
Important: Pay attention to the height of the furniture so nothing looks out of place and the proportions feel balanced. A little tip: with matching top panels or trim pieces, you can cleverly disguise transitions. I think it’s really cool how flexible the options are depending on room size and purpose. Have fun planning!
Phoenix30
7 May 2019 08:12
tutan schrieb:
My tip is that PLATSA works really well with BESTÅ because of its modular flexibility, as both systems harmonize nicely with neutral tones like white or oak.
I find this assessment reasonable but would like to add an important point here: While PLATSA offers great versatility with variable heights and depths, BESTÅ is generally designed with standard heights. As a result, when combining the two, you might need to fine-tune with cover panels or additional legs—this mainly affects the visual alignment and evenness.
tutan schrieb:
With KALLAX, on the other hand, I would rather go for contrasts—such as PLATSA in a subtle wood finish and KALLAX in white, or vice versa.
That is an interesting approach, but it should be noted that KALLAX, with its square grid design and quite industrial look, doesn’t always blend seamlessly with the more minimalist and streamlined style of PLATSA. This combination tends to work better in creative spaces rather than in traditional living rooms.
So, for those who value a cohesive overall appearance, I recommend paying close attention to color and material choices and carefully planning room layout and usage.
KarTristan
8 May 2019 10:34
To add: PLATSA mainly offers advantages in small space concepts through its customizability. When combining it with BESTÅ, I recommend choosing identical or at least very similar fronts and handles. This greatly enhances the visual cohesion.
Furthermore, it is important to plan the function of the connected elements—that is, how the storage will be used. For example, BESTÅ works well for media furniture, while PLATSA can provide additional storage tailored precisely to corner spaces.
When combining with KALLAX, I see more limitations because the sizes and usage principles differ significantly. If you still want to use both systems, you should especially pay attention to clear separation lines—such as distinct zones within the room or additional design elements—to avoid a cluttered overall appearance.
Overall, I recommend roughly experimenting with measurements during planning and preparing room layouts digitally or on paper to avoid purchasing mistakes.
