ᐅ How do I clean Malm surfaces after construction work?
Created on: 9 Feb 2020 08:27
Dillonpo59
Dillonpo59
9 Feb 2020 08:27
Good morning everyone,
I recently worked with Malm furniture and now I am wondering how to gently yet effectively clean their surfaces after some DIY work. The surface is matte sealed, and I want to avoid any damage or dissolution.
Specifically, I am looking for a cleaning method that removes paint residues, dust, or smaller adhesive remains without affecting the matte finish. Are there any specific cleaning products or home remedies that have proven effective?
Also, which tools—cloths, sponges, special brushes—are best suited for this?
I look forward to your tips and experiences, preferably with explanations of why each method is particularly suitable. Thanks in advance!
RonJarrett
9 Feb 2020 09:41
Hello Dillonpo59,
In general, caution is advised when cleaning matte Malm surfaces, as harsh cleaning agents can damage or roughen the sealant.
It is recommended to clean only with lukewarm water and a soft, lint-free cloth. If the dirt is more stubborn, you can add a drop of mild dish soap, but use it very sparingly.
For adhesive residues or paint stains, gentle solvents like isopropanol on a soft cloth are suitable; test first on an inconspicuous area.
Avoid abrasive cleaners, rough sponges, or chemical cleaners containing alcohol, acetone, or ammonia, as these can dull or damage the surface.
Tools: microfiber cloths without texture are ideal. Sponges should be very gentle and non-abrasive.
Summary:
1. Remove dust without pressure (soft drying)
2. For stains: mild soapy water with a soft cloth
3. Test adhesive residues with isopropanol
This way, appearance and protection are preserved.
PERON
9 Feb 2020 12:03
Hello everyone :-)
In my opinion, the key with matte surfaces like Malm and similar items is to avoid getting them unnecessarily wet or scrubbing them. These surfaces want to keep their matte elegance and not end up with a glossy finish 😉
My tip: If it’s just dust, a dry microfiber cloth is enough – simply wipe over gently.
For stubborn dirt, I prefer a lightly dampened cloth with a mild dish soap. Not too much water though, because the surface can absorb it and cause stains.
If there are adhesive residues, sometimes a little miracle cleaner called “lemon” can help – but test it on a small corner first, since the acid can also damage matte surfaces.
So: be gentler than you think, and clean more often rather than scrubbing later! 😉
Dillonpo59
9 Feb 2020 14:19
RonJarrett schrieb:
Basically, when cleaning matte Malm surfaces, caution is advised because aggressive cleaners can damage or roughen the sealant.
Thank you, RonJarrett, for the clearly outlined advice! Especially the warning about acid-based or ammonia-based products is very helpful, as I’ve often heard that matte surfaces are particularly sensitive to harsh substances.
Regarding your recommendation for isopropanol: How quickly or intensively should it be applied? I assume that prolonged or strong application could also cause damage, correct?
And about microfiber cloths: Can you say something about the optimal texture or stiffness? Some cloths have coarser weaves – which ones would you recommend?
Thanks also to PERON for the "lemon tip" – it sounds almost too good to be true, but I will cautiously try it as a last option for small adhesive residues.
tra_nina
10 Feb 2020 07:53
In addition to the useful tips already provided, I would like to add that with matte Malm surfaces, the physical impact from rubbing is at least as important as the choice of cleaning agent.
When removing paint residues, for example, you should never use excessive force or sharp tools to avoid damaging the sealing.
If stains have already dried or hardened, soaking them with damp cloths before the actual cleaning is recommended.
I also advise against leaving aggressive solvents or cleaning agents on the surface for an extended period. It is best to apply briefly, wipe off, and then check.
An important tip: After cleaning, wipe the surface again with a dry, soft cloth to prevent water spots.
If anyone is interested, I can prepare a checklist of do’s and don’ts.
PECLARISSA
10 Feb 2020 10:17
Hello everyone! 🙂
I’d like to add a tip about using certain products: Sometimes a few drops of baby oil or furniture oil can help soften sticky residues, making them easier to remove.
Of course, use sparingly and gently massage it in with a cloth – then wipe thoroughly with clean water to avoid leaving any oily residue.
This works really well, especially if adhesive residues are particularly stubborn.
Don’t lose the fun in cleaning – rubbing too hard can quickly damage the matte finish. So it’s better to be gentle and take good care of your workspace! 😉
Good luck!
