ᐅ What tools do I need to assemble Malm furniture?
Created on: 23 May 2020 09:12
DRA_MA
DRA_MA
23 May 2020 09:12
I am planning to assemble some furniture from the Malm series by IKEA soon, but I have little experience with furniture assembly so far. My question to the community is: Which tools are absolutely necessary for assembling Malm furniture? I especially want to know if it makes sense to use more than just the usual Allen key tool that comes with most furniture, and if there are additional tools that could make the assembly more efficient and safer. I will mainly be assembling dressers and small cabinets, so it would be helpful if you could share tips on standard tools as well as alternatives or optional aids.
Kinbu
23 May 2020 09:47
Hello, this is a very good and detailed question that concerns many beginners in furniture assembly. Generally, IKEA provides the appropriate Allen key with the Malm series, which is sufficient for most screws. However, I definitely recommend also having a Phillips screwdriver, as some screw connections are easier to fasten with it.
DRA_MA schrieb:
Which tools do I absolutely need for assembling Malm furniture?
Besides screwdrivers, a small hammer is also useful to carefully tap wooden dowels in without damaging the material. For more convenience, you might consider a ratchet with an Allen bit, since turning is much faster than with IKEA’s small plastic key.
And very importantly: a clean, sturdy workspace and sufficient lighting – this is often underestimated. Without good visibility, assembly takes much longer.
NOAHSAU
23 May 2020 10:15
Interesting question. I would say many people just start with the basic minimalist toolkit from IKEA and then improvise as they go.
Kinbu schrieb:
a ratchet with a hex bit is more convenient
I generally agree with that, but honestly: for such simple furniture, you don’t need a full set of tools right away. In my experience, most recommendations in forums involve far too much equipment, which in the end only wastes time switching tools. You can get everything done with a good screwdriver and a bit of patience.
That said, I agree that a hammer should be on hand, but for me personally, the hex key alone is absolutely sufficient for Malm.
TANBLA
23 May 2020 10:42
An Allen key, a Phillips screwdriver, and a small hammer are sufficient. If available, a ratchet with an Allen bit speeds up the work. Otherwise, no special tools are needed.
Danabla
23 May 2020 11:05
From a technical standpoint, the following tools are useful for Malm furniture: a metric Allen key, usually 4 mm (5/32 inch), which is included in the package. A Phillips screwdriver size PH2 for the fittings. Optionally, a ratchet with the appropriate Allen bits can speed up assembly. A rubber mallet or small wooden hammer helps insert the wooden dowels without causing damage. The workspace should be flat, clean, and well-lit. Specialized power tools are not necessary and may damage the material if not used properly.
lise56
23 May 2020 11:33
I believe the need for tools should also be considered in terms of the quality and durability of the furniture.
NOAHSAU schrieb:
For such simple furniture, you don’t need the entire toolbox right away.
That is basically true, but if you build furniture more often or want to achieve better stability, more precise tools can also improve the quality of the joints. A properly fitting Allen key prevents over-tightening of screws – often a problem with inexpensive furniture.
Additionally, it is worthwhile to maintain the correct distance between dowels and screws during assembly, which is easier to do with a short ruler or caliper. Therefore, investing in a small set of basic tools pays off in the long run.
