ᐅ How can I permanently eliminate the squeaking noise from Malm furniture?
Created on: 13 Sep 2020 18:23
sautau
sautau
13 Sep 2020 18:23
I have a problem with my Ikea Malm furniture, specifically the drawers that constantly squeak when I open or close them. It’s quite annoying, especially since there doesn’t seem to be a particular reason – the furniture is only about two years old and hasn’t been heavily used.
I have already tried taking the drawers apart and reassembling them, as well as applying some silicone spray to the drawer slides, but the effect was only temporary.
My question is: how can I permanently eliminate the squeaking in Malm furniture drawers? Are there any proven methods that work long-term without damaging the furniture? I would prefer not to replace any parts if there is a simple solution.
Thank you for your tips and experiences!
kla65
13 Sep 2020 18:30
Hi, silicone spray is the right choice, but you need to thoroughly clean the tracks before applying it. Dust or dirt often prevent a lasting effect.
Ellis
13 Sep 2020 18:37
Sometimes, simply applying candle wax to the contact surfaces helps. This can be more effective than spray and is more cost-efficient.
Kyler10
13 Sep 2020 18:45
The squeaking usually occurs due to a lack of lubrication or small friction points on the sliding rails and rollers.
For a long-lasting fix, I recommend the following steps:
1. Completely remove the drawer.
2. Clean the sliding rails with a lint-free cloth and isopropanol.
3. Treat the sliding surfaces with a high-quality grease or dry lubricant. Silicone spray is effective but sometimes only lasts for a short time.
4. Reinstall the drawer and carefully open and close it several times.
It is important to thoroughly clean before lubricating and to use the appropriate lubricant: special dry lubricants are suitable for wood-metal combinations.
pautanner
13 Sep 2020 19:02
I experimented a bit with cooking oil on my Malm drawers – yes, it doesn’t sound high-tech, but it stopped the annoying squeaking. Try it on a small area first; it can’t hurt. 🙂
jelite
13 Sep 2020 19:15
Hello sautau,
I have a small step-by-step guide that I would recommend to you:
1. Gently pull the drawer out of the cabinet.
2. Remove dust and dirt from the runners and runner slats. Small particles often accumulate there and cause squeaking.
3. Use a mild cleaning agent or isopropanol for cleaning, but be careful not to soak any wooden parts.
4. After drying, you can apply suitable furniture wax or paraffin to wood-on-wood surfaces (such as wooden edges) – for metal parts, it’s better to use a dry lubricant.
5. If the drawer feels too loose, also check the screws and guides and tighten them lightly if necessary.
In summary: cleanliness, proper lubrication, and adjustment are key.
Good luck!
