ᐅ How do I clean Malm furniture after renovation work?
Created on: 9 Nov 2022 19:23
Ronla
Ronla
9 Nov 2022 19:23
I hope someone can help me, as I am currently facing the challenge of cleaning and maintaining my Malm furniture (bed and dresser) after extensive renovation work. These are white lacquered surfaces made of engineered wood, which have become heavily soiled with paint dust, adhesive residues, and fine construction dirt.
My specific question is: What effective and gentle cleaning methods or products are particularly suitable for cleaning Malm furniture after renovation work without damaging the lacquer, surface quality, or material?
I want to avoid any risks when choosing cleaning agents (for example, no solvents that could damage the lacquer) while still thoroughly removing stubborn dust and contaminants.
I would greatly appreciate tips on cleaning procedures and suitable products. Thanks in advance!
Best regards, Ronla
Lotizar
9 Nov 2022 20:01
Hello Ronla,
When cleaning Malm furniture after renovation work, care must be taken not to damage the surface. Malm furniture typically has a painted finish that can be sensitive to harsh cleaning agents.
I recommend the following procedure:
1. Dry cleaning: First, remove loose dust and dirt with a microfiber cloth to avoid scratches.
2. Damp cleaning: For more stubborn dirt, lightly dampen a soft cloth with warm water and a few drops of mild dish soap. The cloth should be damp, not wet.
3. Gentle cleaning solution: Alternatively, use a cleaner specifically designed for painted furniture. These products are available at hardware stores and are recommended for delicate surfaces.
4. Avoid solvents or abrasive cleaners: Do not use acetone, alcohol, or abrasive cleaners, as these can damage the paint.
5. After cleaning, wipe the surface with a dry cloth and do not leave it damp.
If there are adhesive residues, I suggest carefully removing them with a solvent explicitly intended for furniture surfaces, such as a special adhesive remover from a specialized retailer.
I hope this helps you.
FeAndreas1
10 Nov 2022 08:47
Hello Ronla,
I would like to address your concern in more detail, as cleaning painted furniture after renovation work can indeed be a challenging task. In particular, furniture like Malm, as you described, has a melamine resin-coated surface that is durable against scratches and light moisture but sensitive to strong solvents and abrasive cleaners.
The following method has worked well for me:
1. Remove coarse dirt and dust with a vacuum cleaner (ideally with an upholstery nozzle) or a soft microfiber cloth to minimize any abrasive effect.
2. For paint dust, which is often very fine and stubborn, a mixture of warm water with a mild, neutral cleaning agent (pH-neutral, e.g., detergent without additives, no esters or alcohols) is suitable. The cloth should be only lightly dampened to prevent water from penetrating surface joints or edges.
3. Adhesive residues (e.g., painter’s tape residues) can often be carefully removed with a soft plastic scraper. A specialized adhesive remover or isopropanol at a very low concentration (70%) can be used sparingly for support. Be sure to test in an inconspicuous spot, as isopropanol may cause matte spots in some areas.
4. After cleaning, wipe the furniture thoroughly with a dry, lint-free cloth to avoid any residue.
5. Optionally, after complete drying, you can apply a furniture care wax or spray designed for painted surfaces to refresh the protection.
It is important to avoid aggressive solvents such as acetone, gasoline, or nail polish remover, as these can permanently damage the surface. Abrasive cleaners should also be avoided because they can damage the matte or glossy finish.
If you are wondering about steam cleaners: I would advise against using them, as the high temperature and moisture can harm the surface.
Have you noticed any specific stains, such as dried paint or filler? Then I could provide more tailored advice.
Best regards!
theota
10 Nov 2022 14:12
I find it interesting how carefully the "sacred finish" is treated here. Sure, Malm furniture isn’t made of solid wood, but the surface is actually quite durable, especially for everyday use.
Lotizar schrieb:
No solvents or abrasives: Avoid acetone, alcohol, or abrasive cleaners, as they can damage the finish.
I don’t agree with that rule so strictly. Of course, you shouldn’t be too aggressive, but a little isopropyl alcohol has never caused me any lasting damage as long as it’s not overused. My advice: with some care and sensitivity, you can also use stronger agents when you need to quickly remove a lot of dirt.
At least when it’s just about paint dust or glue residue, the concerns are often exaggerated. Naturally, I wouldn’t spray nail polish remover directly on the furniture, but we could all afford to be a bit more pragmatic 😉
It’s interesting that there are such different opinions here. What experiences do others have?
Ethan
11 Nov 2022 09:56
Hello Ronla,
Based on my experience, I would like to share the following advice:
You should always start with the gentlest cleaning method and only increase the intensity if necessary. The recommended sequence is: dry dusting, damp cleaning, and then spot-treating more intensively.
I have had good results using a damp microfiber cloth soaked in lukewarm water with a drop of neutral dish soap. It is important to use the cloth well-wrung to avoid any moisture damage.
For adhesive residues or stubborn construction dirt, I recommend using a product designed for delicate surfaces that can remove substances like silicone or adhesive residues (for example, a specialized furniture cleaner usually available from trade suppliers, often citrus-based and solvent-free). This way, you can treat these areas specifically.
FeAndreas1 schrieb:
Klebereste lassen sich häufig mit einem weichen Kunststoff-Schaber sehr vorsichtig lösen.
I fully agree with this; careful mechanical removal keeps the risk to a minimum.
theota schrieb:
ein bisschen Isopropanol hat bei mir bisher nie irgendwelche dauerhaften Schäden verursacht
Isopropanol can work, but you should definitely test it on an inconspicuous spot first. The coating can react differently depending on the batch.
I wish you good luck with the cleaning – feel free to share here how it went if you like!
