ᐅ How do I build IKEA Metod kitchen islands with countertop and storage?
Created on: 22 Aug 2022 19:43
Blawinold
Blawinold
22 Aug 2022 19:43
Hello everyone, I am currently planning to build an IKEA Metod kitchen island that provides both a sturdy work surface and enough storage space. My specific question is: How do I assemble a kitchen island with Metod cabinets so that the countertop is stable enough while still leaving sufficient storage space behind the cabinets, without making the island too wide or cumbersome? I’m particularly interested in how to arrange the carcasses, which cabinet types are best suited (e.g., drawers, shelves, or doors), and how to properly place and secure the countertop. Additionally, I am looking for tips on material selection and installation to ensure the island is durable and functional. Does anyone have experience or concrete advice regarding planning, assembly, and installation? Thanks in advance!
warrenka57
22 Aug 2022 20:36
Blawinold schrieb:
How do I assemble a kitchen island with Metod cabinets so that the countertop is stable enough while still leaving enough storage space behind the cabinets, without making the island too wide or cumbersome?
I know this well because I recently built a Metod island myself. It’s important to secure the cabinet carcasses properly—I connected them with extra brackets to increase stability.
Regarding cabinet types: I mainly chose drawers since they are more accessible and make optimal use of the storage space. Shelves may look more open, but in my opinion, they are less practical for an island that you want to use from multiple sides.
You should mount the countertop on well-secured cross supports. I added wooden battens to fix the countertop firmly. This way, nothing wobbles, even if you work with some force.
Last but not least: plan enough space around the island so it doesn’t feel too dominant. Especially when several people are in the kitchen, an island that is too wide or too deep quickly becomes annoying.
Takutau
23 Aug 2022 09:27
Blawinold schrieb:
I’m particularly interested in how to arrange the cabinet carcasses, which types of cabinets work best (e.g., drawers, shelves, or doors), and how to properly place and secure the countertop.
That’s a good and well-considered question. I recommend first defining how you want to use your island: Do you mainly want a large work surface or more storage space? This will determine how the cabinets can be arranged.
- For storage: Base cabinets with drawers are ideal due to their efficient use of space. You can also use corner solutions with carousels if the island corners allow it.
- For work surface: The countertop should be as continuous as possible, without visible seams or supports that might disrupt your workflow.
- Countertop: IKEA offers various options, but many choose engineered stone tops or solid wood slabs, which are easy to work with and secure. It’s important to treat the surface before installation (e.g., oiling, sealing).
Installation ideally happens in two steps: first build and secure the carcasses, then add cross braces for reinforcement, and finally install the countertop. Also, pay attention to the height, which should be ergonomic for cooking and working (around 90 cm [35 inches], depending on your height).
I would advise using sketches or 3D planning during the design phase—this lets you immediately verify if the width and depth are right.
gesar32
24 Aug 2022 13:59
This is a crucial point. For the stability of a Metod kitchen island, the following technical details should be considered:
- Use sturdy LAT mounting profiles or solid wood battens as supports under the countertop.
- Screw the cabinet carcasses together using connector screws (Minifix or cam lock connectors).
- Heavy countertop overhangs without substructure should be avoided, as they can cause sagging.
- Cabinets with drawers (e.g., Maximer drawers from Metod) offer the best access but should be precisely aligned before installation.
- Make sure that toe kicks or feet are at the same height to compensate for any unevenness in the floor.
You should also consider the load-bearing capacity of the material: particleboard is stable but not designed to be water-resistant. A countertop made of solid wood or high-quality composite is more durable.
Finally, I recommend carefully studying the high-quality assembly instructions and technical drawings from IKEA before starting the installation. This will help you avoid mistakes and future problems.
