ᐅ How can I build an IKEA Besta as a bench with integrated storage?
Created on: 26 Jul 2024 08:47
kin45
Hello everyone, I am planning to convert the IKEA Besta system into a bench with integrated storage. I am particularly interested in how to construct and reinforce the modules so that the seating surface is stable enough for daily use, without the structure wobbling or getting damaged. It would also be helpful if someone could share tips on how to open the storage compartments under the bench—especially how to best incorporate drawers or flap mechanisms without them falling out of the main frame or affecting the seating surface. Are there any recommendations regarding the choice of materials or fasteners that specifically focus on stability and durability? I have already reviewed the standard IKEA instructions but could not find detailed guidance on benches. Thanks in advance for your help!
dijan
27 Jul 2024 12:18
Kinbu schrieb:
As a general rule, maintain a minimum distance of 2-3 cm (1-1.2 inches) from the edge of the screw to the edge of the material to prevent splitting.
2-3 cm (1-1.2 inches) is usually sufficient, but a little extra space never hurts. I also recommend countersinking the hole slightly after drilling; this gives the screw a clean hold and prevents splitting. Doing a bit of this also helps later when upholstering!
Fitigu
27 Jul 2024 13:45
In summary: For a stable bench seat using IKEA Besta, it is essential to combine plywood reinforcements, a central support beam, and secure fastening methods. Choose a suitable wooden panel for the seating surface and screw it to the carcasses. Drawer slides or flaps must be designed compatible with the reinforcements to ensure functionality and stability are maintained. Avoid placing screws too close to the edge, pre-drill holes, and use wood glue to increase durability. This way, you achieve a practical and sturdy bench with sufficient storage space.
