ᐅ How do I build an IKEA Metod kitchen island with an integrated workspace?
Created on: 7 Feb 2023 08:07
Gekyle
Gekyle
7 Feb 2023 08:07
I am planning to build an Ikea Metod kitchen island with an integrated work area and am looking for tips on optimal planning and implementation. Specifically, I am interested in how to arrange the modules so that they are stable, provide enough storage space, and at the same time offer a functional work surface with sufficient room for cutting and food preparation.
I would also like to know whether it makes sense to choose special countertops or if the standard Ikea countertops are sufficient, especially regarding durability and maintenance. How do you usually handle the assembly of the island, particularly the connection of the base cabinets to each other and the attachment of the countertop?
I look forward to your experiences, including advice on common mistakes or valuable tips for assembling the Metod kitchen island. Thanks in advance for your support!
Nabla64
7 Feb 2023 12:41
Hello Gekyle,
your question is quite comprehensive, so I’d like to give you a structured overview on building a Metod kitchen island with a workspace:
- Planning: First, take precise measurements of the available space and consider how wide and long the island should be. The Metod base cabinets typically come in 60 cm (24 inches) widths, so you can place modules side by side.
- Stability: It is important to securely fasten the cabinets together using the supplied connecting hardware. Also, use brackets and screws to anchor the entire island to the floor—especially on tile or hardwood flooring.
- Worktop: Ikea offers various worktop options, including laminate, solid wood, and quartz composite. Solid wood has a warm, high-quality appearance but requires maintenance. Laminates are low maintenance but more susceptible to UV damage and mechanical wear. For a kitchen island that will see heavy use, I recommend a durable surface like solid wood or quartz composite.
- Assembly: Work systematically from the bottom up. First, connect the base cabinets using the connecting fittings, attach the feet at an even height, and then place the worktop on top. Use Ikea’s worktop mounting clips, which are sturdy and easy to install.
- Tips: Pay careful attention to leveling the cabinets accurately—unevenness can later damage the worktop or cause doors to rattle.
A common mistake is not sufficiently connecting the cabinets or improperly attaching the worktop, which can cause problems over time.
If you want more detailed information, just let me know!
Mufato
7 Feb 2023 14:22
I would recommend securely connecting the Metod base cabinets with metal connectors and fixing the countertop with the original mounting clips. For the work surface, choose solid wood or quartz composite, as they are more durable than laminate.
ju_ren
8 Feb 2023 09:33
Nabla64 schrieb:
Make sure to level the cabinets precisely
I can confirm that. I didn’t do this with my island, and now some parts rattle. It’s also important to set all the legs to the same height beforehand.
GiRoyce
9 Feb 2023 16:48
Hello Gekyle,
to further explain the assembly of an Ikea Metod kitchen island with an integrated workspace:
It can be helpful to first draw an accurate grid on the floor. This way, you can see how the modules can be positioned relative to each other and whether additional adjustments like side panels or trim pieces are needed.
When connecting the base cabinets, the included "Metod connector bracket" provides initial stability, but it’s worth mentioning that many users also use extra brackets and screws to make the entire structure more secure. This is especially important for islands that cannot be fastened to a wall.
Regarding the countertop, it’s worth considering the thickness: a countertop with at least 2.8 cm (1 inch) thickness is recommended to prevent sagging, especially when it spans multiple modules. The countertop is typically attached with the supplied clips, but some users add extra clamps for added safety.
The integrated workspace can also be expanded with built-in features such as a sink with a draining board or additional electrical outlets (power sockets or USB ports), depending on your needs and planning.
If you want to equip your island with special functions like pull-out countertops or extra drawers, Ikea also offers suitable accessories that fit well with the Metod series.
If you like, I can also help you with a detailed list of materials and tools or provide tips for the precise assembly!
