ᐅ What is the best way to clean Malm furniture to remove water stains?
Created on: 7 Apr 2020 09:17
dardan
Hello everyone, I recently noticed some unsightly water marks on my IKEA Malm furniture that appeared after placing glasses or cups on it. The surfaces look slightly spotted and dull, even though they are made of lacquered MDF. My question is: What is the best way to remove these water marks from Malm furniture without damaging the surface? Which cleaning products and methods do you recommend to help the furniture retain its original shine and protection? Thanks in advance for your tips!
Regarding the question about the frequency of furniture maintenance, my recommendation is:
For lacquered surfaces used daily, apply a protective layer every 6 to 12 months. If the furniture is frequently exposed to liquids, for example from regularly placing drinks on it, a shorter interval of 3 to 4 months is advisable.
Regular maintenance not only preserves the appearance but also protects the lacquer from microscopic cracks and intrusions such as moisture. It is important to let the surface dry thoroughly after each cleaning and not to leave any moisture behind.
Please also keep in mind that polishing too often with highly abrasive products can deteriorate the lacquer finish.
LuMarcel438 Apr 2020 12:26Good summary from dardan and kauti. I see one more gap: What about long-term damage if the water stain remains on the surface for years?
But if the water marks have penetrated deeper into the paint layer, then polishing won’t help anymore, right? In that case, only repainting or sanding will work?
Does anyone have experience with when removing these types of stains becomes only a cosmetic issue?
dardan schrieb:
For visible watermarks, suitable furniture polishes can be helpful
The question about the depth of water damage is justified. In general, if water has penetrated the paint surface over an extended period, it can cause cloudiness or discoloration in the paint itself, which cannot be fully removed by simple cleaning or polishing methods.
In such cases, the only option is to sand down the surface and then repaint it.
For the surfaces of the Malm series, this is usually too complex and uneconomical in practice. Therefore, prevention and early cleaning of stains is the best approach.
My advice: Never wait, but act immediately upon noticing water marks.
