ᐅ How do I attach Ikea PLATSA shelves to wooden panels?
Created on: 12 Nov 2022 08:47
Dasoba
Dasoba
12 Nov 2022 08:47
Hello everyone, I am planning to attach several Ikea Platsa shelves to the existing wooden panels in my home office. The panels are relatively thin, about 12 mm (0.5 inches) thick, and serve as wall cladding, which I do not want to damage. Although the Platsa modules are flexible in terms of installation, I am unsure how to securely and stably fix the shelves to the wooden panels without them eventually falling off or damaging the panels themselves. Does anyone have practical experience with mounting Platsa shelves on wood-paneled walls? Which screws, anchors, or other fastening methods would you recommend, especially regarding load capacity? I look forward to your tips and to hearing which solutions have proven successful for you.
giabau
12 Nov 2022 09:13
Hello Dasoba,
I can gladly provide you with a structured approach that is recommended for attaching PLATSA shelves to wood panels:
- First, make sure your wood panels are mounted on a load-bearing substructure, as thin panels alone usually cannot support the weight of the shelves adequately.
- If the panels are directly fixed to a solid wall (e.g., wood studs or masonry), try to aim for the substructure when mounting.
- For attaching the PLATSA, you can use a cordless screwdriver and countersunk wood screws, ideally with a diameter of at least 5 mm (0.2 inches).
- It’s best to use long screws (at least 60 mm (2.4 inches)) to reach through the panels into the load-bearing wall.
- Make sure to pre-drill with a thin drill bit before screwing to avoid splitting the wood.
- If the panels are hanging on the wall without a supporting substructure, it is advisable to screw on additional wooden slats (e.g., cross slats on the back) to create a solid base to which you can then attach the shelves.
Common mistakes I often see are using screws that are too short or not pre-drilling, which can damage the wood and make the mounting unstable. In summary: the main point is to find or create a load-bearing layer behind the wood panels and then use appropriately long wood screws.
I hope this helps you already!
sifope
12 Nov 2022 10:32
giabau schrieb:
Common mistakes I often see are using screws that are too short or not pre-drilling, which damages the wood and makes the mounting unstable.
That’s a good point, but for me, the question is whether it’s really sufficient for load capacity to simply screw through the panel into the wall. Depending on how the substructure is designed, it might be that you don’t actually reach a solid supporting structure. I would therefore question whether something like a battens doubling or additional furring strips is absolutely necessary, especially if you plan to carry a lot of weight on the shelves.
Also: what about the attachment of the PLATSA-specific brackets? Are they even suitable for direct mounting on thin wood panels, or are strongly reinforced anchor points required? I find that it’s often assumed that wood panels provide a stable base, without really knowing how load-bearing they are – which in the worst case can lead to unpleasant surprises.
Dasoba
13 Nov 2022 08:05
sifope schrieb:
I would therefore question whether something like adding furring strips or additional battens is really necessary
Thank you for the critical question, it makes sense. I actually mounted the panels on the wall, and behind them is a timber stud wall with irregular spacing between the studs (between 50 and 80 cm (20 and 31 inches)) – so it’s not fully continuous.
This likely means I can’t screw directly into a stud everywhere. However, I can attach wooden battens in certain spots through the panel to then fix the shelves onto them.
My idea is to first install these vertical battens to create a solid foundation.
Could this be a practical solution? What dimensions and types of battens would you recommend so they can support the PLATSA system’s load effectively? And is it advisable to always screw through the panel and batten into the studs behind? Or is it sufficient to attach the battens to the panels with shorter screws only?
giabau
13 Nov 2022 09:54
Dasoba schrieb:
My idea is to first install these vertical battens to create a solid base.
Exactly, that’s a sensible approach.
I would offer the following tips:
- Battens should be at least 30x40 mm (1.2x1.6 inches) in size, preferably a bit thicker for added stability.
- It’s best to use construction timber that is straight and not warped.
- Secure the battens directly to the studs using long screws (at least 70 mm / 2.7 inches). This provides very strong anchor points.
- Then you can fix the panels onto the battens with shorter screws, so the battens carry the load.
- For the final shelf screws, you can screw through the panels into the battens again. This ensures a solid fixing.
In summary: The battens act as a substructure for the shelves. If you choose a cavity fixings solution, this is less practical with thin panels since you need a secure anchor in load-bearing wood.
One more tip: Consider not only attaching the shelves to the back wall but also supporting them additionally with wall brackets if possible.
This way, you can ensure a long-lasting and secure installation.
Gofoman
13 Nov 2022 12:18
In such cases, I always wonder if it wouldn’t be more practical to at least partially remove the entire wood panel wall and replace it with a more stable wall structure—perhaps drywall with OSB boards or something similar, which are known for bearing heavier loads.
I’ve always found it somewhat questionable to hang shelves on such thin panels, especially since they can later be heavily loaded.
Let’s be honest: Adding battens or furring strips is work too, and in the end, it’s just a compromise. It’s better to adjust the wall a bit if you don’t want risky fastenings.
Of course, this takes time and money, but in the end, you have a truly sturdy base for all sorts of things and won’t be surprised by loosely hanging furniture later on.
What do you think? Do you really get lasting results with old wood, panels, and trim, or is renovating the wall like this a better long-term solution?
