ᐅ Are there ways to add casters or wheels to Ikea PLATSA shelving units?
Created on: 18 Mar 2024 08:17
Se-arinHello everyone,
I am considering fitting my IKEA Platsa shelving unit with casters to make it more flexible and easier to move around the room. My specific question is: Are there any options or proven methods to equip IKEA Platsa shelves with casters without compromising stability or significantly altering the assembly? I am especially interested in versions with swivel casters that are both sturdy and integrate well into the existing shelving structure.
If anyone has experience or recommendations, I would be very grateful for advice on suitable types of casters, necessary modifications to the shelving unit, or alternative solutions. Thanks in advance!
loken schrieb:
Simply attach sturdy casters (preferably with brakes) to the bottom panels, and the shelf can be easily rolled around.Thanks for the tip. I’m also curious whether this affects the load capacity. Is the standard cabinet assembly sufficient, or should reinforcements be considered? Especially for taller shelving units. Anyone have an assessment on this?
The stability of a PLATSA shelving unit on casters depends heavily on the type of casters and their mounting. Generally, I recommend:
- Choose casters with a load capacity of at least 30 kg (66 lbs) per caster.
- Use casters with mounting plates that provide at least four screw points.
- Reinforce the frame with additional support using wooden strips or metal brackets.
- For tall shelves, it is advisable to add a back panel reinforcement to prevent tipping.
This way, you ensure that mobility does not come at the expense of stability.
flo-Theres19 Mar 2024 07:50A brief practical note: If the PLATSA shelving unit is placed on casters, it is important to choose casters with a locking brake. This is especially important for taller and heavier shelving units to prevent unwanted rolling, particularly on smooth floors.
Additionally, I recommend carefully planning the position of the casters before assembly – not too close to the corners to reduce leverage and maintain stability.
