Hello everyone, I am planning to install IKEA Platsa shelves in my apartment, but I have drywall, and I am unsure how to securely fix the shelves to it. The Platsa units are quite heavy, especially when fully loaded. My question is: How can I reliably and safely attach IKEA Platsa shelves to drywall without damaging the wall or risking the shelves falling off eventually? What fastening materials and methods are best suited for this? I look forward to your tips and experiences!
Hi! Great that you brought up this topic, Platsa is really versatile and flexible. 😊 For drywall partitions, I always recommend using special cavity anchors or metal expansion anchors that securely grip behind the board. It’s important that the load is not carried only by the drywall panels but, if possible, also by the underlying wooden or metal framework. With heavy shelves, you should never rely solely on drywall; instead, always screw at least into the studs! Good luck, you’ve got this! 💪
Hello pausfra, I can fully understand how important secure mounting is with drywall, especially for heavy furniture like the IKEA Platsa shelves. A simple screw directly into the drywall often isn’t enough – this is a common cause of damage or accidents. Special hollow wall anchors are recommended; these spread out behind the drywall and provide a larger surface area for support. It is important to carefully locate the studs (wood or metal studs) behind the drywall before drilling – preferably using a stud finder. Screwing directly into these studs greatly increases the load-bearing capacity. If the framework is not reachable, always use good quality metal expansion anchors. Also, do not exceed the maximum load capacity of the anchors; for heavily loaded shelves, it’s better to use multiple fastening points rather than only two. If the back panel of the shelf has metal profiles, it is also possible to secure these to the wall with angle brackets while the unit is installed, which in turn should be fixed with appropriate anchors. I hope this gives you a good overview – feel free to ask for more details if you like!
naudan schrieb:
A simple screw into the drywall often isn’t enough – this is a common cause of damage or accidents.Thanks for the tip! I was aware of the studs behind the drywall, but I’m not sure if the stud finder works reliably in my somewhat older house.
vinpau schrieb:
With heavy shelves, you should never rely only on the drywall; always screw at least into the studs!So, once I’ve located the studs, can I mount the shelves directly using long wood screws? Do I need to pre-drill? And what about the boards that are between the drywall and the studs – won’t the screws damage those?
I’ve also read that alternatives like metal brackets or additional plywood panels behind the shelves in the drywall cavity can help distribute the load better. Does anyone have experience with that?
I’d appreciate any further tips to work as stably as possible while keeping the installation flush with the wall.
Hey, glad to see so much quality information coming together here! 😎 Especially with drywall, you don’t want the shelf to weaken or even fall down eventually – that would be a problem. Regarding pre-drilling: yes, definitely pre-drill! Otherwise, the screw can easily split the stud, and the hold will be weaker.
Using plywood panels is a great idea to distribute the load – you can basically install them as a large, stable backing behind the shelf and then secure them to the wall at multiple points. This way, the load is spread better across the wall surface, not just on a few anchors.
Metal brackets are also excellent because they help reduce the weight load and you’re basically fixing the shelf as if supported by a second hand. Simple, practical, and professional! 🔧
Good luck – and let us know how it goes! 🍀
