ᐅ How do I mount IKEA Metod wall cabinets on drywall?
Created on: 27 Nov 2022 14:03
kenpau
I am planning to mount IKEA Metod wall cabinets on a drywall system. The wall consists of standard gypsum plasterboard panels with the usual metal stud framework. I am wondering which fixing options are sensible and secure to ensure the cabinets are not only load-bearing but also permanently stable. Are there any special anchors or mounting methods you would recommend? I am also interested in whether it is better to drill directly into the metal studs or if another option is preferable. Any advice on weight distribution and the correct procedure for drilling would be greatly appreciated. Thank you in advance!
kenpau
28 Nov 2022 09:20
Thanks in advance for your tips!
One more follow-up question: How is the load distribution when mounting several wall cabinets side by side? Is it sufficient to fasten the attachment points of each cabinet separately to the studs, or should I use some kind of continuous rail (e.g., wooden batten or metal bracket) to better distribute the load? My idea was that such a rail would at least reduce the tension on the drywall. How do you handle this in practice?
U
usbla
28 Nov 2022 10:07
Regarding load distribution for multiple IKEA Metod wall cabinets on drywall:
It is technically advisable not to transfer the load only at single points. Mounting directly on metal studs is primarily statically and mechanically robust. However, if these studs are not optimally aligned or if the cabinets have a greater length, a substructure can be helpful. A solid wooden batten spanning the attachment points distributes the tensile forces more evenly across the drywall and the metal studs. It is important that this batten itself is firmly and directly fastened to the metal studs to avoid overloading the drywall panels. This reduces the risk of cracks and damage and ensures the cabinets remain securely mounted in the long term.
PAREL
28 Nov 2022 11:30
kenpau schrieb:
Is it sufficient to screw the attachment points of individual cabinets directly into the profiles, or should I use some kind of continuous strip (e.g., wooden batten or metal bracket)?
A strip or mounting rail always provides additional stability and helps distribute the load. This is especially useful for longer wall cabinets or when hanging multiple cabinets to create a continuous support. You should:
- Attach the strip directly to several metal profiles.
- Use adequately sized screws (at least two screws per profile).
- Ensure the strip itself is not too thin; 18 mm (0.7 inch) plywood or OSB are good options.
I have done this several times myself, and it results in fewer "wobbly" spots and better protection against damage to the drywall.
kenpau
29 Nov 2022 08:59
usbla schrieb:
Mounting directly onto the metal studs is primarily structurally and mechanically stable.
Thank you for the detailed explanation! That makes sense. So I should first locate the metal studs and then attach a wooden batten across them, securing it with sheet metal screws. The cabinets can then be screwed directly onto the batten, right?
One last question: Is there anything additional to consider for the batten itself (e.g., a protective coating or treatment) to ensure a durable installation?
U
usbla
29 Nov 2022 09:43
kenpau schrieb:
So I should first locate the metal studs and then attach a wooden batten horizontally, securing it with sheet metal screws. The cabinets can then be screwed directly onto the batten, right?
Exactly.
Regarding the batten:
- A simple, smooth wooden batten made of spruce or pine is usually sufficient.
- Applying a surface treatment (e.g., wood varnish or stain) is recommended to prevent moisture damage, especially if the wall areas are in damp rooms.
- Pre-drilling the screw holes helps reduce splitting in the wood.
- Make sure the batten is mounted flush to ensure a secure and neat installation.
This way, your construction will be durable and stable.
