ᐅ How do I attach IKEA Metod kitchen cabinets to concrete walls?
Created on: 7 Sep 2024 08:37
JONTA
JONTA
7 Sep 2024 08:37
Hello everyone, I am currently planning to install an IKEA Metod kitchen in my rental apartment, where the walls are made of concrete. I have a question about how to best and safely attach the Metod kitchen cabinets to concrete walls. I want to carry out the installation so that the cabinets remain stable and durable in everyday use. Specifically, I would like to know: Which anchors and screws are most suitable for concrete walls? Should I check the wall for cracks or uneven areas beforehand, or are there any special preparations I need to consider? Also, how should the load distribution be handled when hanging multiple cabinets on one wall? I would be very grateful for practical tips and experiences, especially from those who have already installed Metod kitchens on concrete walls. Thank you in advance!
INGRID34
7 Sep 2024 11:52
Hello JONTA, for concrete walls, I always use heavy-duty anchors or expansion anchors. It is important to insert the anchor deeply enough (about 8 cm (3 inches)). Screws with a minimum diameter of 6 mm (1/4 inch) are usually ideal. Check the wall for unevenness beforehand using a spirit level. You distribute the load best by connecting the cabinets with a horizontal brace – this provides more stability.
Filippo
7 Sep 2024 14:46
Hi JONTA, your question is really relevant, especially since concrete walls can be challenging depending on their condition. Generally, I recommend the following steps for mounting IKEA Metod kitchen cabinets on concrete walls: First, check the condition of the concrete—are there any hollow spots, or is the wall solid? A simple knock test can help determine this.
For anchors, heavy-duty metal anchors, such as those from Fischer or Würth, are typically suitable, with a minimum size of 8 mm (depending on the weight of the cabinets). These provide good support even for heavy loads. Drilling with a hammer drill using a masonry bit of the appropriate size is essential. Important: drill the anchor holes deep enough (at least 8 cm (3 inches)) and make sure to clean out the dust thoroughly (by blowing or vacuuming) to ensure proper hold.
As for screws, galvanized or stainless steel hex-head screws have proven reliable to handle mechanical stresses well.
Regarding load distribution, you should fix the Metod cabinets to the wall at multiple points if possible. Using a horizontal mounting rail or mounting profile to hang all the cabinets is recommended, as it distributes the forces better than individual, separately mounted cabinets.
One more thing: before installation, check the wall for irregularities using a spirit level. If the wall is uneven, placing shims or insulation strips behind the cabinets can help them hang straight and distribute pressure evenly.
I would also like to know how heavy the individual cabinets are and how many you plan to hang in total. This could affect the choice of anchors.
Ramon4
8 Sep 2024 09:12
Filippo schrieb:
First, you should check the condition of the concrete – are there voids or is the wall solid? A simple knock test can help here.
This is a very important point that I want to emphasize again. Concrete walls can be hollow or porous depending on the construction method, and this fundamentally affects how fixtures can be attached.
Also, if you plan to install several Metod wall cabinets, I recommend using a mounting rail, as Filippo mentioned. This allows you to distribute the load better, keeping the cabinets securely in place.
Furthermore, I have had good experience using a drill hole depth gauge or drill stop in addition to anchors and screws. This prevents drilling too deep or not deep enough.
One last safety note: if your wall is old or has visible cracks, it’s worth inspecting the building structure, possibly with a professional. Especially for kitchen cabinets that will bear a lot of weight, you don’t want to take any risks.
How do you plan to proceed? Have you been able to test the walls yet?
