ᐅ How can I install IKEA Metod cabinet doors to ensure they close quietly?
Created on: 24 Apr 2019 08:17
Judasren64
Hello everyone, I have a fairly specific question regarding the installation of IKEA Metod kitchen cabinet doors. My goal is to mount the doors so that they close as quietly and smoothly as possible, without compromising stability or alignment. So far, I am using the supplied hinges, but the closing is often somewhat loud, which is disruptive in my open-plan kitchen. Are there any technically proven methods or specific hinge adjustments, possibly additional dampers, that you would recommend? Maybe you also have tips on how to install the doors so that the door stop is softer or less abrupt. I am open to all suggestions, including alternative fastenings or supplementary components that promote a quiet closing mechanism. Thanks in advance!
Declan55
25 Apr 2019 14:36
keohudson schrieb:
Is this really the only solution?
Well, definitely not the only solution! But it is the most effective and fastest one. 🙂 I know some prefer to do it without any upgrades. However, the price for the soft-close kit at IKEA is quite reasonable, and installation is very easy.
For adjustment:
- If you slightly loosen the screws on the hinge, you can move the door horizontally and vertically.
- The depth adjustment is controlled by a rotary screw.
This is often enough to properly align the doors. Still, soft-close helps a lot with loud closing noises!
GU-LAU60
25 Apr 2019 14:59
Soft-close dampers are almost essential if you want quiet closing. In addition, the door needs to be properly adjusted.
Also:
- Regularly check the screws on the hinge
- The door must fit snugly in the frame
- Do not overload the door panels
There isn’t much more to it. Otherwise, the only solution is to change the door material, which can be expensive.
Fitigu
26 Apr 2019 07:55
Summary from a technical perspective:
- The Metod hinges are generally well sized but only achieve significant noise reduction through soft-close adapters.
- Adjustment of the hinges along three axes (height, depth, side) is essential. Inaccuracies lead to increased closing pressure and thus noise.
- Rubber buffers or door dampers as additions can extend the hinge lifespan and reduce impact shocks.
- The material of the carcasses is limited due to particleboard, making elastic dampers practically necessary.
If the goal is to have permanently quiet doors, soft-close is unavoidable. The cost is manageable, and installation effort is minimal. Alternatively, hinges from third-party manufacturers with integrated soft-close function can be used, but these usually require minor modifications.
Espen
26 Apr 2019 10:21
Buying soft-close, installing it, adjusting hinges correctly, done.
Without soft-close, nothing stays quietly beautiful over time.
