ᐅ How can I secure Billy shelves in rental apartments without using wall plugs (anchors)?
Created on: 12 Jul 2024 09:23
Tillpin
I am looking for ways to secure my Billy shelves in my rented apartment without using wall anchors. The issue is that I am not allowed to drill holes in the walls, and standard clamp or plug-in systems do not seem stable enough. Are there proven methods or alternative fastening techniques that work without penetrating the wall mechanically? It would also be helpful to know what kind of loads these solutions can handle and whether it is possible to avoid wall anchors even with larger or heavier shelves.
I look forward to expert advice and shared experiences!
I would like to add some technical details:
Fastenings without anchors rely heavily on the wall surface. On smooth wallpaper or painted walls, the load-bearing capacity of adhesive systems is often limited, especially when moisture or temperature fluctuations occur.
A proven system is so-called “tension rods” made of metal with rubber pads at the top and bottom to distribute pressure. These are installed between floor and ceiling, the shelf rests against the wall and is clamped with brackets or thumb screws—this presses it firmly against the wall without drilling.
Important: The room height must be measured precisely to the millimeter, otherwise the clamping pressure may be insufficient or overstretching could damage the surface.
Tip: You can also attach small heavy-duty brackets directly to the shelf, fixed with tape or double-sided adhesive pads to prevent tipping if drilling is not allowed.
Do you have any specific conditions, such as a different wall structure or baseboards?
Dilen schrieb:
Do you have any special conditions, perhaps a different wall structure or baseboards?Thank you for the detailed tips. Yes, I do have specific conditions: The walls are covered with woodchip wallpaper on drywall, which is not very strong for adhesives. Baseboards are present, about 10 cm (4 inches) high. The ceiling is smoothly finished and approximately 2.55 m (8 feet 4 inches) high. There are slight temperature fluctuations in the room due to the heating, especially in winter.
pikin schrieb:
Lightweight items and decorations can be securely fixed with adhesive or clamp solutions, but bookshelves require a stronger mountingExactly, the shelf is mainly intended to hold books and CDs, which do have considerable weight. Stability is therefore very important to me. Thanks to everyone for the advice so far!
It’s interesting that primarily tension rods and clamping methods are being suggested. But honestly – how durable are these really in the long run? Especially with textured wallpaper on drywall, I see a high risk that the entire shelf will come loose or the surface will get damaged after just a few months.
These baseboards can often be a stumbling block, as ceiling tension rods only work if they rest completely flat against both the floor and ceiling. This issue is often underestimated.
My recommendation: prioritize a freestanding solution or at least accept small minimally invasive measures that the landlord might approve. Otherwise, safety and the condition of the walls will suffer in the long term. Just gluing and clamping sounds risky to me when dealing with “heavy books.”
Tillpin schrieb:
Baseboards are present, about 10cm (4 inches) high\
to wrap up the discussion, I would like to present a practical solution:
A combination of a freestanding shelf and so-called shelf anchors, which are used to prevent tipping. These anchors are usually attached to the shelf itself using clamps, completely avoiding the need to drill into the wall. This way, the shelf stands stable without wall plugs – especially if it is not heavily loaded.
Additionally, I recommend reinforcing the shelves by adding cross braces. This reduces wobbling and the risk of the shelf tipping over.
If you are planning future moves, this method is flexible and can be removed without leaving marks, which is a big advantage in rental properties.
