ᐅ How can I assemble IKEA Metod cabinets securely in tight spaces?
Created on: 5 Feb 2021 08:36
duloso
Hello everyone, I am planning to install IKEA Metod cabinets in my small kitchen, but I have very limited space available, which makes installation challenging. My question is: How can I assemble IKEA Metod cabinets in tight spaces in the most sturdy and stable way without compromising load capacity or safety? Specifically, I am interested in which assembly techniques, reinforcements, or modifications you can recommend from experience to ensure the cabinets remain durable and securely wall-mounted even with limited room.
kogudra schrieb:
Use more durable back panels, such as a 6 mm (1/4 inch) plywood sheet instead of the standard thin particleboard.I'm a bit confused about this because IKEA usually recommends using the original back panels. Are there common issues when switching to a different type of board? Has anyone here had experience with this regarding stability and compatibility with the fixing points?
Perhaps this could also allow for an additional mounting point on the wall.
Leonardteo6 Feb 2021 11:30duloso schrieb:
Are there typical problems when switching to a different panel?I have done this a few times. The key is to cut the plywood panel precisely to the dimensions of the original back panel and drill all the mounting holes accordingly. This significantly improves stability without making installation more difficult.
One point to be cautious about: because the plywood is slightly thicker, you may need to adjust the door hinges a little. The hinges are adjustable, but this should be taken into account.
Other than that, I can recommend this method, especially if the cabinets are installed in places where they experience a lot of stress.
duloso schrieb:
Have others here had experience regarding stability and compatibility with the mounting points?I have installed plywood back panels in several kitchen projects. It is important to cut the panels precisely and drill additional holes for the wall fixings. The stability improves significantly, while the weight increases only slightly.
In short: No typical issues, rather benefits due to increased rigidity and better options for fastening.
