ᐅ How can I build IKEA Metod cabinets to maximize space efficiency?
Created on: 31 Jan 2021 10:12
RANAU5Hello everyone, I am planning to install several Ikea Metod kitchen cabinets in my kitchen and want to optimize the use of space as much as possible. Specifically, I am interested in how to best combine the different cabinet sizes and internal components to maximize storage – especially in corners and under the countertop. Which installation steps are particularly important to ensure everything is stable while maintaining the greatest possible volume in a limited area? Are there any proven tips or special configurations that go beyond the standard Ikea instructions? I would appreciate any advice, including recommendations on planning software, suitable interior fittings, and practical experience with the assembly.
Hello RANAU5, your question is very practical and can be answered well in several steps. First of all, I recommend doing detailed planning before assembly—either digitally using the Ikea planner or by creating a schematic sketch. With Metod, there are standardized cabinet heights (80cm (31.5 inches), 60cm (23.6 inches), 40cm (15.7 inches)) and depths (37cm (14.6 inches)) that you can combine to make the best use of the space.
For corners, be sure to use the “corner base cabinet door” or rotating corner units so that you can actually access the storage space easily. Inside, use pull-out drawers or baskets that can be fully extended. These significantly increase usability compared to fixed shelves.
When assembling, pay attention to securing the side panels firmly to the base and top panels. The Metod units are sturdy enough if the connecting screws are tightened properly and the included brackets for wall mounting are used. Installing the plinths is also important to ensure stable footing.
Summary:
- Precise planning and measuring
- Use corner solutions and pull-out drawers
- Careful assembly with fixed connections and wall brackets
- Customize interior fittings to individual needs
If you want more detailed guidance on specific steps, I’m happy to help.
Summary:
Matthewt481 Feb 2021 08:47kemads46 schrieb:
Make sure the side panels are securely connected to the base and top boards during assembly.This is indeed a crucial point. I once had a setup where this wasn’t done properly – the cabinet stood, but later felt quite unstable. Another important aspect for me is the interior fittings:
- Use full-extension drawers with a soft-close feature, as this allows you to access storage space much more efficiently.
- Combine different basket and compartment sizes to keep dishes, pots, and pantry items stored separately and neatly.
Personally, I always plan for two to three different adjustable elements so you can adapt the storage space as needed.
By the way: It’s best to work with two people during installation, as the cabinets can be somewhat heavy and awkward without experience.
I understand that the desire to make the most of available space can be challenging—especially if you don’t assemble furniture every day.
Personally, I initially doubted whether I could use corners effectively. Small adjustments, like a rotating basket in the corner cabinet and various pull-out interior solutions, really helped me to see how I could utilize the space.
In my opinion, it’s worthwhile to carefully consider what you want to store before starting the assembly—what are your current storage needs? Otherwise, you might spend a lot of time assembling something that doesn’t fit perfectly.
I’m definitely keeping my fingers crossed that your planning goes well and that the cabinets bring you joy for a long time.
Matthewt48 schrieb:is a great tip that significantly reduces stress and frustration.
Working with two people during assembly
For optimal space utilization with Metod:
- Use corner cabinets with carousels or drawers.
- Install pull-out drawers instead of fixed shelves.
- Choose compartment heights according to the items.
- Use wall brackets for stabilization.
Best to assemble step by step following the instructions.
