ᐅ How do I assemble IKEA Hemnes drawers with soft-close slides?
Created on: 27 Jun 2022 10:37
Tan_go39
Tan_go39
27 Jun 2022 10:37
Hello everyone, I am currently facing the challenge of retrofitting soft-close drawer slides to IKEA Hemnes drawers. Specifically, I need advice on how to properly install the soft-close mechanism to ensure the drawer closes smoothly. So far, I have the slides and drawer fronts separated, but I find the installation of the damping components a bit unclear. Additionally, I am unsure whether certain screws need to be installed differently or if there are special instructions regarding the alignment of the guide rails. Does anyone have experience or a step-by-step guide that could help me replicate the original drawer function, especially the soft-close feature? Thank you in advance!
draleo
27 Jun 2022 13:02
Tan_go39 schrieb:
So far, I have kept the rails and the drawer fronts separate, but I find the installation of the soft-close elements a bit unclear.
To properly retrofit the soft-close slides of the Hemnes drawers, I recommend the following structured approach:
- First, identify the soft-close unit on the rail (the small plastic module with a spring mechanism).
- On the inside of the drawer box, there are designated mounting points for these dampers.
- Position the guide rails so that the soft-close units at the rear end of the rail snap into the corresponding recesses in the drawer cutout.
- When installing, ensure the rails are perfectly parallel and level to avoid jamming or malfunction.
- Use the original IKEA screws, which are typically wood screws with a special head designed for the guide rails.
It often helps to fully separate the drawer beforehand to install the soft-close mechanism separately. If you have questions about a specific assembly step, I am happy to assist.
nubar
27 Jun 2022 15:48
draleo schrieb:
Position the guide rails so that the damping units at the rear end of the rail snap securely into the corresponding recesses in the drawer cutout.
This is an important point. I would like to add that with the Hemnes series, the orientation of the rails is critical because the damping function only works effectively if the soft-close drawer slide is installed on the designated side.
Additionally, it is important to ensure that the rails are not only mounted straight but also that the damping mechanism is not mechanically blocked in any way. If you notice the soft-close feature is not functioning, check whether the metal or plastic part of the guide rail is properly aligned and free of debris.
These details significantly affect the closing behavior.
V
Victor54
28 Jun 2022 11:26
draleo schrieb:
When installing, make sure the rails are perfectly parallel and level to prevent jamming or malfunctions.
That is, of course, correct, but I would even go further: how reliable are these installation dimensions from IKEA in general? I have noticed in the past that the fit can vary depending on the quality of the workpieces and twisting during drilling.
Does anyone have systematic experience on how to correct deviations when the rails do not operate smoothly despite careful installation?
Also, I doubt that replicating the soft-close drawer slide fully works without original replacement parts. The spring mechanisms are quite specialized. Are there any compatible alternative solutions or DIY options that can be used?
PAREL
29 Jun 2022 08:14
Victor54 schrieb:
Does anyone have systematic experience on how to correct deviations when the rails don’t run smoothly despite careful installation?
Here is my short tutorial for properly installing the soft-close slides of the Hemnes drawers:
- Step 1: Prepare the components and check the drill holes, making slight adjustments if the fittings are not precise.
- Step 2: Mount the guide rails on both sides of the cabinet, using a spirit level and tape measure to ensure parallelism and correct height.
- Step 3: Insert the damping unit on the rear rail cap. This unit often clicks into place but is properly seated only when you feel it snap securely.
- Step 4: Assemble the drawer and adjust the front panel, since the drawer slide works together with the damping system here. The front should be adjusted so that it gently touches the damping unit without obstructing it.
Common mistakes:
- Rails mounted out of parallel
- Damping unit not fully engaged
- Front panel pressed too far down, causing the damping element to be blocked
Conclusion: With some care and accuracy, the reassembly can be successful. Spare parts should be checked carefully. In case of deviations, it is worth rechecking all dimensions before final assembly.
