ᐅ How can I adapt IKEA Brimnes furniture to fit unusual room dimensions?
Created on: 24 Jul 2023 10:23
NINA32Hello everyone, I have a question that might concern many of you: What is the best way to adapt the IKEA Brimnes furniture series to unusual room dimensions? In my case, the room where I want to place the furniture is not a simple rectangle; it has various wall recesses, angled corners, and several small ledges that make it difficult to install complete wall units.
Since I am particularly interested in the dressers and cabinets from the Brimnes range, which offer different sizes and layout options, I am looking for practical tips or proven methods to adjust these furniture pieces to irregular room profiles without a lot of waste, expensive custom modifications, or losing important storage functions.
Are there, for example, ways to modify individual elements or combine them effectively? How do you handle the challenges posed by corners and recesses? What accessories or custom adjustments have worked well? I am very much looking forward to your experiences and solutions!
Hello Nina32, your concern is completely understandable, and I think it’s great that you explained it so clearly because unusual room dimensions can really make things difficult—especially with standard furniture like Brimnes.
I had a similar situation myself, and it was quite daunting. What helped me was first doing precise measurements: I made a detailed sketch including all the irregularities and then considered which Brimnes pieces could be combined well without leaving large gaps.
I also had to be brave about cutting and modifying—such as shortening shelves or adjusting back panels. There are also official IKEA accessories like cover panels that can help conceal some joints.
One tip from me: if you’re thinking about using several identical modules, you can arrange and move them around in different ways for flexibility. Although the furniture is not custom-made, with a bit of creativity you can make it fit well.
Don’t worry, many people face this. The important thing is not to be too perfectionistic but to focus pragmatically on functionality.
NINA32 schrieb:
In my room, where I want to place the furniture, it is not a perfect rectangle, but has different wall niches, slanted corners, and partly several small recesses
The most important thing first: measure, measure, measure, and write down the dimensions. Afterwards, you can combine Brimnes units or adjust the shelves. For niches, smaller sections often help, for example chests of drawers instead of a full wall unit. For angled corners, you can place furniture flush and fill tight gaps with shelves or decorative items.
To effectively adapt the IKEA Brimnes range to unusual room dimensions, the following structured approach is recommended:
- Measure the room accurately and create a detailed drawing to document all recesses and alcoves.
- Select Brimnes modules with variable widths and heights to allow maximum flexibility in combining pieces.
- Modify the furniture by shortening shelves or removing back panels, if necessary and technically feasible.
- Use filler panels or spacers from IKEA accessories or custom-made elements to close visual and functional gaps.
- Check whether individually cut shelves or modifications to the hardware system are possible to optimize storage according to the room’s contours.
It is important to carry out proper planning before installation, for example using a furniture planner or CAD software, to avoid incorrect purchases and adjustment issues. Combining standard modules with customized parts can be very successful this way.
This approach is proven and saves time and costs compared to fully custom-made solutions.
