ᐅ How can doors be retrofitted onto an old KALLAX unit?
Created on: 1 Feb 2022 08:03
sidar35
Hello everyone, I’m planning to add doors to my old IKEA KALLAX shelf, as I want to make the open storage space a bit more enclosed to better keep things tidy and protect against dust. Now I’m wondering: What is the most efficient way to install suitable doors on an older KALLAX unit that originally came without doors? Are there special mounting kits or assembly instructions that work well to attach the doors securely and in an attractive way? I am especially interested in any alternative solutions to the usual IKEA KALLAX doors or matching fronts, possibly DIY options or hacks that make installation easier or reduce the cost. I would really appreciate any well-founded recommendations, personal experiences, or tips for preparation and handling when retrofitting doors. Thanks in advance!
koneo
2 Feb 2022 10:48
In such cases, it helps to fill the old holes with wooden dowels or wood filler and then use new screws in a different position. It is important that the surface is clean and even; otherwise, installation will be difficult.
sidar35 schrieb:
Does anyone have experience with using special wood filler or reinforcement panels to stabilize the fixing holes on an old KALLAX?
I have always had good results working with two-component wood filler. When it comes to stabilizing larger areas, thin plywood or multiplex panels are suitable, which can be fitted flush on the inside and securely screwed in.
If you are using dowels, you should also use longer screws to improve the hold. For the doors themselves, I recommend hinges with longer arms that can compensate for small tolerances.
Emery
3 Feb 2022 13:04
Another option for adding doors to an old KALLAX shelf unit is to use clamp or snap-on systems that require no screws and do not put stress on the side panels.
These systems work with special brackets that simply clamp between the shelves. This way, damaged side panels are protected, and stable doors can still be installed.
theota schrieb:
Why would anyone really rely on IKEA when there are DIY solutions that look better, are more stable, and have that extra character?
That is true, but not everyone has the space or time to plan extensive custom builds. For the average user, such clamp-on solutions are often a practical interim option.
SUPE2
4 Feb 2022 07:11
If you want to retrofit doors on an old KALLAX, take a look at the original IKEA brackets. If the holes are loose, fill them with wood filler and let it dry thoroughly.
Screw the hinges onto thin MDF panels, which you then attach to the shelves. This way, you protect the unit and achieve neat doors.
Magnetic catches provide a secure hold and prevent rattling.
