Hello everyone, some time ago I bought an IKEA Hemnes furniture piece (specifically a sideboard from the series) and have recently noticed that the surface is showing some minor scratches and signs of wear. Since I would like to use the furniture for a longer period and preserve its value, I’m wondering: How can IKEA Hemnes furniture be effectively protected against scratches? I’m especially interested in which protective measures or care products have proven effective, whether special sealants or films can be used, and what the best approach is without negatively affecting the appearance or feel of the material. Who has practical experience or useful tips on how to protect the typical lacquer or surface of the Hemnes series in the long term? I look forward to detailed advice, including recommendations on mistakes to avoid.
Hello Edil66, I will gladly address your question step by step and share some practical tips that have proven useful when working with IKEA HEMNES furniture.
First, a few basics: The HEMNES series is usually made from pine wood, coated with a thin layer of lacquer or stain – these surfaces are relatively sensitive to scratches and everyday wear.
To protect the furniture from scratches, I recommend the following approach:
- Protection with pads: Always place felt pads under vases, decorative items, or other harder objects that rest on the surface. This reduces mechanical abrasion.
- Cleaning: Avoid harsh cleaning agents; use only soft microfiber cloths with mild water or special wood care products.
- Maintenance: After cleaning, you can apply a furniture polish suitable for lacquered wood – this creates a light protective layer and refreshes the finish.
- Sealing: For extra protection, some users alternatively use thin transparent films or special wax treatments; however, I suggest testing these first on smaller, less visible areas.
Common mistakes include:
- Using aggressive cleaning agents
- Leaving wet spots on the wood for too long (water damages wood)
- Placing heavier items directly on the wood without any protection
In summary: Prevention through appropriate pads, gentle cleaning, and targeted care products is key to preventing scratches in everyday use. For deep scratches, sometimes refinishing or wood repair kits can help, depending on the extent of the damage.
If you need more details about specific care products, I’m happy to provide further advice.
harold schrieb:
Sealing: For additional protection, some users alternatively use thin transparent films or special wax treatments, but I recommend testing this first on smaller, less visible areas.I would critically note that while films can offer temporary surface protection, they do not address the underlying sensitivity of the material. Often, a film can impair the breathability of the wood surface, which could lead to damage over time. Therefore, it is important to carefully check which films are used and whether they are truly breathable.
Furthermore, I find that the discussion so far lacks consideration of the durability of paints or clear coatings that can be applied as an additional layer. I would like to hear about experiences regarding whether these coatings can be applied easily without damaging the original finish.
I tend to look at this question from a slightly different angle: it is not only about prevention but also about how to deal with small damages when they occur. Either by professional repair or by using homemade methods to visually conceal them.
Therefore, my question to the community is: which products are truly durable and gentle on the material, without spoiling the appearance of the HEMNES furniture?
Johnathon2 Aug 2016 21:46Edil66 schrieb:
How can IKEA HEMNES furniture be effectively protected against scratches? I am particularly interested in which protective measures or care products have proven effective, whether special sealants or films can be used, and what the best approach is without negatively affecting the appearance or feel of the material.A very good question that addresses the balance between protection and preserving the original aesthetics. I would like to explain in more detail an approach that has worked well for me – importantly, this involves no experiments with chemical sealants or films, but rather a natural, craft-based method.
Step 1: Clean the surface. I use slightly dampened cotton cloths and a pH-neutral wood cleaner, never harsh chemicals. It is essential to remove all dust particles to prevent micro-scratches.
Step 2: Apply a water-based hard wax oil glaze (available specially for furniture) in a very thin layer. This product is clear and absorbs well without being sticky or forming a thick film. It creates a natural protective layer that can be easily renewed.
It is important to always let the layer dry thoroughly and then lightly sand it with fine sandpaper (e.g., grit 320). This ensures optimal adhesion of subsequent layers.
Step 3: Regularly maintain the furniture with natural wood furniture oil, which preserves the wood’s flexibility, protects against drying out, and keeps the surface smooth.
I would advise against laminate films or aggressive sealants – these often change the feel of the surface and can peel over time.
neo59 schrieb:
I would critically point out that while films offer short-term surface protection, they do not address the underlying vulnerability of the material.I fully agree. For a long-lasting result, I recommend organic care that allows the wood structure to breathe, preventing internal stresses.
I would also be interested in how others handle mechanical stress when, for example, children or pets use the furniture. Are additional protective measures necessary?
