ᐅ How can you easily align Ikea Pax doors?
Created on: 17 Nov 2023 20:07
V
viktorron
V
viktorron
17 Nov 2023 20:07
Hello everyone, I’m currently assembling an Ikea Pax wardrobe and encountering the problem that I can’t get the doors properly aligned despite multiple adjustments. Specifically, I mean adjusting them vertically and horizontally so that the doors don’t warp, close evenly everywhere, and are all at the same height.
How can Ikea Pax doors be easily aligned without spending hours experimenting? Is there perhaps an effective step-by-step guide or special tips that help achieve consistent gaps between the doors at all points? I’m especially struggling with adjusting the hinges and pivot points.
I would really appreciate concrete advice or experiences that can help achieve a faster and cleaner perfect result.
pa-wolf
17 Nov 2023 20:45
The simplest method is to first adjust the horizontal alignment at the lower hinges, then make vertical adjustments at the upper screws.
Always make only small adjustments and test how the door feels when opening and closing after each change.
Matthewt48
17 Nov 2023 21:01
Hello Viktorron, I can understand your situation well; aligning Pax doors can be a bit tricky at first.
Basically, there are three screws on the Ikea hinges that can be adjusted horizontally, vertically, and in depth.
- The horizontal screw adjusts how close or far the door sits from the cabinet frame.
- The vertical screw controls whether the door moves slightly up or down.
- The rear screw changes the side-to-side gap.
One tip is to initially fasten the doors only loosely, then roughly adjust all the gaps, and after that make the fine adjustments step by step.
If you like, I can also write a short step-by-step guide that many find helpful.
KIN42
18 Nov 2023 08:33
I would like to add that not only is adjusting the hinges crucial, but it is also important to ensure that the Pax carcass itself is perfectly level. Even slight deviations or uneven floors can make aligning the doors difficult.
Use a spirit level to make sure the carcass is correctly aligned. If necessary, you can use the cabinet’s adjustable feet to compensate for any unevenness in the floor. Only then does fine-tuning the doors really make sense.
kasan
18 Nov 2023 11:16
Matthewt48 schrieb:
The rear screw adjusts the side clearance.
That is only partially correct. I often notice that the “rear screw” on the hinge actually controls the door’s depth.
Interestingly, the effect also depends on the type of hinge (for example, clip-on vs. overlay hinges) and how they are installed. For a consistent alignment, it is important to follow the correct sequence of screw adjustments and to understand which screw affects which axis. Otherwise, it’s easy to end up with a misalignment.
GALENKU
18 Nov 2023 12:47
My experience: first adjust the vertical alignment using the screws on the upper and lower hinges, then adjust horizontally and in depth. After that, check whether both doors close evenly.
Sometimes it helps to screw the doors in a bit more loosely at first, so you can move them more easily. Once everything fits properly, tighten the screws fully.
