ᐅ How can Ikea Hemnes furniture be protected from scratches?
Created on: 26 Dec 2022 09:17
Sebubau
Sebubau
26 Dec 2022 09:17
Hello everyone, I am looking for efficient methods and proven tips to protect Ikea Hemnes furniture from scratches. I am especially interested in which surface treatments, protective films, or home remedies work best without affecting the appearance of the solid wood furniture. Since wood surfaces can develop minor damage quickly, it would be great to get advice on how to care for the wood long-term and protect it from mechanical scratches. Are there specific products that work well for Hemnes, or are simple DIY solutions better? I look forward to your experiences and recommendations!
Marlenepa
26 Dec 2022 09:48
Hello Sebubau, it’s great that you’re approaching this topic in such detail! Ikea Hemnes furniture is typically made of solid pine wood, which is sturdy but relatively prone to scratches due to the softer type of wood. I generally recommend:
- Applying a thin layer of furniture wax or wood oil to protect the wood surface and make it more resistant.
- Purchasing and using transparent protective films on heavily used areas, such as tabletops or dresser surfaces.
- Exercising caution when using home remedies, as many can discolor or damage the surface.
It is also important to clean the furniture regularly to remove dust particles that could cause scratches. If you like, I can recommend some specific products. Let me know which room the furniture is in and how it is used!
Peose
26 Dec 2022 11:02
Hey Sebubau! 🙂 I love the Hemnes series, but scratches are definitely an issue, especially with kids or pets around! What really helps are felt pads on all contact points of the furniture – this protects not only the floor but also the edges of the furniture itself.
You can also use special clear varnishes that create a thin protective layer. I once used a water-based sealant that was quite nice because it didn’t change the wood’s appearance.
And hey, just wiping it gently with a damp cloth more often also makes a big difference! You’ve got this!
KARJU
26 Dec 2022 12:39
Regarding an effective scratch protection strategy for Ikea Hemnes furniture, it should be noted that Hemnes is mainly made from lacquered pine wood, which offers some protection but is not scratch-resistant. Therefore, the following measures are recommended:
- Regular maintenance using appropriate wood care products (wax or oil) to preserve and refresh the protective layer.
- Use of furniture pads or felt pads on contact surfaces, especially where objects are moved or slid.
- Preventive application of transparent polyurethane protective coatings to make the surface more resistant to mechanical impacts.
Please avoid aggressive cleaning agents, as they can damage the lacquered surface.
A combination of these measures is effective in extending the lifespan of Hemnes furniture.
Nathanaelk
27 Dec 2022 07:55
Hello Sebubau, I would like to go into more detail because scratch protection for Hemnes furniture can definitely be considered from a technical perspective. Hemnes furniture, made of pine wood, naturally has a certain softness, which makes it more prone to scratches.
First, it is important to distinguish between painted and oiled surfaces. Most Hemnes products have an opaque white paint layer, which is relatively durable but not invulnerable. Therefore, I recommend the following steps:
1. Cleaning: Use gentle, pH-neutral cleaning agents first, then dry thoroughly.
2. Protective treatment: For painted surfaces, furniture polishes based on silicone are suitable because they slightly strengthen the protective layer and help conceal minor scratches.
3. For areas with higher wear (e.g., tabletops), transparent protective films can be applied. There are special film coatings that are almost invisible and scratch-resistant.
4. Avoid direct abrasion: Use mats or pads under decorations or work areas, such as placemats or felt pads.
One question for you: Are your furniture pieces painted or left natural with oil? That would significantly influence the choice of care products.
Sebubau
27 Dec 2022 10:24
Nathanaelk schrieb:
One question for you: Are your furniture pieces lacquered or treated with natural oil? That would greatly affect the choice of care products.
Thank you for the detailed description, Nathanaelk! My Hemnes dressers and tables are actually lacquered, painted white, with a smooth and sealed surface, but I still notice small signs of wear over time. Therefore, I am inclined to follow the recommendation for furniture polish. Are there differences between these polishes that I should be aware of, especially regarding white lacquer? I want to avoid discoloration as much as possible.
