ᐅ How can Ikea Hemnes furniture be modernized with minimal effort?
Created on: 16 Apr 2023 18:08
KELLS43
KELLS43
16 Apr 2023 18:08
I have several Ikea Hemnes furniture pieces, including dressers and bedside tables, that I would like to update with minimal effort. My goal is to refresh the classic wood look and achieve a more contemporary, perhaps Scandinavian-modern style, without extensive DIY work or expensive materials.
I would like to know which simple yet effective methods you recommend—such as new handles, painting, surface treatments, or similar approaches. It’s important for me to have tips that keep the effort low, ideally avoiding complicated disassembly or restoration work. Also, it would be great if you could share your experiences regarding how durable or sturdy these easy updates are and whether they are truly worthwhile.
Thanks for your tips and tricks on modernizing Ikea Hemnes furniture!
gauvin37
16 Apr 2023 19:23
If I were you, I would start by replacing the handles. New, modern handles are inexpensive and can significantly change the overall look. Adding a matte or satin finish paint in white or gray often helps a lot. Usually, nothing else is needed to update the appearance.
Surela
17 Apr 2023 11:37
Modernizing Ikea Hemnes furniture with minimal effort is easier said than done, but this classic piece offers plenty of room for simple updates. In general, I recommend a step-by-step approach:
- First: Clean the furniture thoroughly and, if needed, sand it lightly to roughen the surface. This ensures better adhesion of paint or finish.
- Second: Depending on the desired look, individual surfaces can be painted, for example, the drawer fronts. A modern, matte paint in muted colors (anthracite, dusty blue, cream white) immediately creates a fresher appearance.
- Third: Replace the handles. Metal handles in matte black or brass add accents and give a high-quality impression.
- Fourth: For larger dressers or cabinets, sometimes adding simple furniture feet is worthwhile to lift and “neutralize” the piece. There are inexpensive universal furniture feet available, which can be screwed onto the underside.
- Fifth: For surface treatment, furniture wax can be used; it protects and gently darkens the finish if that fits the style.
It is important to sand well before painting and to use the appropriate primer; otherwise, the paint will not last long. Also, keep in mind that painting requires drying time depending on the environment and may need several coats. If you have questions about the exact process or materials, feel free to ask—also how exactly your furniture looks, as that helps to give better advice.
How exactly are the Hemnes pieces currently finished? Are they solid wood or veneer? This affects the choice of color and treatment.
Tinaneo
18 Apr 2023 09:44
Interesting question and well put. However, I question the generality of common tips like "changing handles" or "simply repainting." It is important to consider the material quality of Ikea furniture like Hemnes: Hemnes is partially solid wood, but many larger surfaces of the dressers are veneered.
gauvin37 schrieb:
If I were you, I would start by changing the handles.
Changing handles does alter the appearance, but it only brings a minor effect, which really becomes noticeable when combined with paint or surface texture.
Surela schrieb:
First: Thoroughly clean the furniture and if necessary, sand it lightly to roughen the surface.
Completely agree! Simply painting without preparation risks chipping. I also find the contrast between the surface and the handles important – a matte finish combined with differently colored, perhaps even more ergonomic handles can achieve a genuine update.
What bothers me: Some users recommend "attaching furniture legs." While this does raise the piece and make it feel a bit lighter, it significantly changes the style. You should carefully consider if this fits the rest of the room.
My thoughts: It’s less about "minimal effort" and more about "targeted effort" to seriously change the style. In that sense, clear color concepts, appropriate material contrasts, and high-quality handles form the core of a modern upgrade. Small details like new knobs or adhesive films often feel kitschy or cheap.
What about lighting or interior arrangement? These are often underestimated factors that can make an old Hemnes appear more contemporary – even without major renovations.
