ᐅ How can Ikea Hemnes furniture be custom painted?
Created on: 19 Aug 2024 12:37
Sumipau
Sumipau
19 Aug 2024 12:37
I recently purchased several pieces of furniture from Ikea’s Hemnes series and would like to paint them myself to better match the look of my home. I’m particularly interested in how to best prepare Hemnes furniture for painting, which type of paint works well to achieve a durable and even finish, and whether there are specific techniques or products to either highlight the wood grain or completely cover it.
Additionally, I would like to know if you have any experience with sanding or primers that are especially recommended for Hemnes furniture. Do you generally aim for a matte or glossy finish?
My goal is a long-lasting, aesthetically pleasing result—I’m willing to invest some effort upfront to avoid disappointment later. I’m looking forward to your tips and also to hearing about mistakes I should definitely avoid!
Thank you in advance.
Filippo
19 Aug 2024 16:03
Hello Sumipau,
Your plan to customize Hemnes furniture by painting it is definitely a project that can turn out very well with proper preparation and the right choice of materials. Hemnes furniture is usually made of solid pine wood or MDF with a wood veneer. That’s why priming is especially important to ensure the paint adheres well and doesn’t peel off over time.
I recommend the following steps, one by one:
- Preparation: Disassemble the furniture and remove all handles, rails, etc. Sand the surface with fine sandpaper (grit 120 to 180) to slightly roughen it. This helps the primer stick better.
- Priming: Use a high-quality, solvent-free interior wood primer if possible, as it has low odor. It seals the wood pores and ensures even paint coverage.
- Paint selection: Choose a water-based acrylic paint, since it remains flexible and is less likely to crack. There are many finish options available, from matte to high gloss.
- Application: Apply several thin coats, sanding lightly between coats (grit 220) to achieve a smooth surface.
- Optional: Use a clear lacquer topcoat if you want extra durability.
If you want the wood grain to show through slightly, you can use stains instead of opaque paint. However, since Hemnes pieces often have smooth surfaces, this requires an appropriate primer.
One more question: Do you plan to paint all furniture pieces uniformly, or are there some you want to treat with special techniques like glazing or chalk effects?
I hope this serves as a helpful general guide! If needed, I can also provide more details about applying specific types of paint.
koduga
20 Aug 2024 10:14
Filippo schrieb:
Primer: Use a high-quality wood primer for interior use, preferably solvent-free, as it has low odor.
I can only confirm this from my own experience. I once painted a Hemnes shelf, and without proper priming, the paint simply didn’t adhere – after a few weeks, unsightly bubbles appeared.
Also, I would definitely recommend taking your time between each step. It’s tempting to want to see results quickly, but the best outcome is only possible if you allow each layer to dry completely. This leads to a much smoother surface without unwanted unevenness in the end.
Filippo schrieb:
If you want the wood grain to show somewhat, you can use stains instead of opaque paint.
I’ve tried that too, but I didn’t like the maintenance of stains in everyday use, as they tend to fade or stain more quickly when exposed to moisture.
The reliability of opaque acrylic paint convinced me, especially for Hemnes furniture, which often gets quite a bit of wear.
I also understand that it can be frustrating when the furniture doesn’t turn out as expected. I wish you plenty of patience and confidence—you will achieve beautiful results!
fredle
21 Aug 2024 18:59
Hello Sumipau,
I’d like to add a brief step-by-step guide specifically for painting Hemnes furniture to help you achieve the best results:
- Disassemble the furniture and remove the handles
- Thoroughly clean the surface (remove dust, grease, and old residues)
- Sand: use 120 grit sandpaper, and for uneven areas use finer sandpaper (180–220)
- Remove dust (best with a tack cloth or a slightly damp cloth)
- Prime: apply a blocking primer or a special wood primer to improve paint adhesion
- Paint: use a high-quality acrylic lacquer, preferably with a roller for flat surfaces or a good brush for corners and edges
- Lightly sand between paint coats (220–320) to smooth out imperfections
- Apply a final clear coat (matte or satin) to protect the paint long-term from scratches and moisture
Common mistakes I often see and recommend avoiding:
- Applying paint too thickly, causing drips or bubbles
- Not allowing enough drying time between steps
- Not completely removing sanding dust before painting
For the finish: Hemnes furniture has many edges and profiles, so it’s worth using a detail brush to get clean edges.
If you want a matte finish, I strongly recommend using a matte clear coat, as many paints tend to have some sheen originally.
I hope this summary helps you avoid unnecessary frustration and achieve results that you can enjoy for a long time.
gregto
22 Aug 2024 09:42
Sumipau schrieb:
how to best prepare Hemnes furniture for painting, which type of paint is suitable to achieve a durable and even finish, and whether there are special techniques or products to either highlight or fully cover the wood grain.
One small addition to your question: If it is important for you to keep the wood grain visible, you could use so-called “tinted varnishes.” These allow the wood to show through while providing protection.
Additionally, before painting, you can apply a wood stain to give the wood a different color tone. The stain penetrates deeply and enhances the contrast of the grain, followed by a clear topcoat.
A fully opaque finish is simpler and usually more durable, but if you want to preserve the character of the wood, it’s worth experimenting with this combination.
If you want a very strong opaque finish, polyurethane or two-component (2K) paints are very durable but can be too complicated for DIY use. Water-based acrylic paints are generally the best choice.
Good luck with your project; with careful preparation, it will surely turn out well!
