ᐅ How do I repair scratches and dents on IKEA Hemnes surfaces?
Created on: 25 Jun 2021 08:37
teomika
Hello everyone, I hope someone here can help me with a rather specific problem: I own several IKEA Hemnes furniture pieces with lacquered wood surfaces. Over time, various scratches and small dents have appeared, which are especially noticeable on the lighter finishes.
My specific question is: What methods or products are best suited to sustainably repair scratches and minor dents on Hemnes surfaces without damaging the original finish or causing uneven touch-ups? Preferably with tips on how to prepare and apply the materials.
I have heard about color markers, special wax sticks, or even furniture polish, but I’m unsure which options are truly effective and easy to do yourself. I would appreciate it if you could share your experiences or mention the pros and cons of different solutions!
Declan55
25 Jun 2021 15:57
Hey teomika! 🎉 I recently had exactly the same problem and was really happy when I discovered the "miracle cure": furniture touch-up markers combined with wax paste!
First, I carefully colored in the scratches with a wax stick, then polished over it with the wax paste. The result: it actually looks like new, with hardly any marks visible! It was important to me that I could do it myself without much effort 😉
Maybe you could give it a try. It’s affordable and saves you a lot of hassle!
maugi
26 Jun 2021 08:14
I’m also in favor of wax sticks, but with a relaxed attitude: you shouldn’t expect the repair to look brand new, but it’s definitely good enough for a quick visual fix! 😊👍
The most important tip: the color of the wax or stick should match the wood tone really well, otherwise it will stand out even more. Just experiment a bit and don’t get discouraged!
And don’t worry, it worked great for me too. On top of that, it’s actually fun to do a little DIY project for the small dents.
GALEO4
26 Jun 2021 12:39
LEOIX schrieb:
Once the surface is damaged, the actual protective layer is lost
That’s exactly what I mean: many people here focus too much on minor cosmetic issues and forget that the protective function of the paint is crucial.
In my opinion, if you really want to carry out repairs, it’s better to take preventive measures for small damages and opt for a professional paint job rather than plastic wax. It may sound harsh, but Hemnes to me isn’t just "cheap" IKEA furniture—it has quality that should be preserved.
I often see all these DIY fixes more as a way to cover up the problem, which adds little long-term value.
teomika
27 Jun 2021 07:22
Palenar schrieb:
I’m curious, have you closely inspected the surface to see how deep the scratches really are?
Thank you for the detailed question! Most of the scratches are superficial, so I would classify them as minor clear coat damage. They definitely don’t reach the bare wood. A few small chips are a bit deeper, showing a lighter contrast compared to the rest of the paint film.
I haven’t tried any treatments yet due to concerns about causing further damage. The polishing option sounds interesting, but I’m not sure if it provides lasting protection to the clear coat or just masks the damage.
Overall, I want to avoid the affected areas becoming either glossier or duller than the surrounding surface. If you can recommend any specific products, I would greatly appreciate it.
angel
27 Jun 2021 10:43
teomika schrieb:
The furniture polish option sounds interesting, but I’m unsure whether it actually provides lasting protection for the clear coat or just masks it temporarily?
Hello, teomika, good question! Furniture polish or clear coat maintenance generally offers surface protection and shine enhancement, reducing the appearance of minor scratches but it does not rebuild or repair the clear coat layer.
For small scratches, this is a gentle method that preserves the existing clear coat and helps prevent further drying out.
If the clear coat is more deeply damaged, you can touch it up with a suitable clear lacquer. However, be careful: the clear coat finish might look different in the repaired area, so test it beforehand.
My recommendation: start by cleaning the surface, then try the polish, and if any flaws remain visible, carefully touch up with clear lacquer where needed.
Palenar
28 Jun 2021 09:19
teomika schrieb:
I haven’t started any tests yet due to the risk of damage.
That’s wise! In general, I recommend testing on an inconspicuous area (e.g., the inside of a drawer) to check how the finish reacts to different products.
With Hemnes, it’s important to avoid using abrasive cleaners or solvents because the clear coat is delicate. If in doubt, it’s better to apply several thin layers of paint rather than one thick coat.
Regarding the “glossy or matte” effect: you can gently adjust the sheen level after painting using very fine sandpaper (e.g., grit 8000), but this requires some practice.
If you want to try the painting yourself, I’d be happy to provide detailed instructions.
