ᐅ How can IKEA Hemnes furniture be cleaned easily and effectively?
Created on: 14 Nov 2015 07:47
X
Xiao64
X
Xiao64
14 Nov 2015 07:47
I own several pieces of furniture from the IKEA Hemnes series and would like to know how to clean them easily without damaging the wood or surface. I am especially interested in effective everyday cleaning methods that quickly remove stains or dust, ideally without harsh chemicals and with minimal effort. What cleaning products and techniques do you consider best for gently yet thoroughly maintaining Hemnes furniture? Are there any specific care instructions from IKEA that you would recommend? Thanks for your tips!
Tatovin
14 Nov 2015 08:12
I simply use a soft, slightly damp cloth and mild dish soap for everyday cleaning. Never wipe with a wet cloth to avoid swelling the wood. For stubborn stains, a special wood cleaner can help, but use it sparingly.
GLORIA
14 Nov 2015 09:35
First: Hemnes furniture is made of painted or oiled wood that should be treated with care.
- For daily cleaning, IKEA recommends using a dry or slightly damp cotton cloth.
- Avoid harsh cleaning agents, solvents, or abrasive products, as they can damage the surface.
- For stains, use a solution of warm water with a mild, pH-neutral dish soap and wipe gently.
- After cleaning, the surface should be thoroughly dried to prevent moisture damage.
- For oiled surfaces, additional care with appropriate wood oils is recommended to nourish and protect the wood.
This approach preserves the durable appearance and prevents premature wear. Regular maintenance is advisable.
glamo8
14 Nov 2015 10:48
I often use a microfiber cloth for my Hemnes furniture, as it is gentle and picks up dust well. Occasionally, I lightly dampen it with water, and that’s all you need.
CHRISTOP33
14 Nov 2015 11:14
Tatovin schrieb:
Never wipe with a lot of water to avoid causing the wood to swell.
This advice is invaluable! I once used too much water, and the wood actually got damaged. Since then, I always use water sparingly.
I usually clean my Hemnes cabinets with a damp cloth and dry them immediately – it’s quick and always keeps them looking well maintained. And if there’s a stain, I use a mild soapy solution. This way, I keep the effort low and the enjoyment of the furniture high!
MELANIE41
15 Nov 2015 06:38
When it comes to cleaning Hemnes furniture easily, I recommend using appropriate cleaning products.
- A dry cloth is sufficient for daily cleaning.
- For stubborn stains, I use a mild water-based cleaner.
- It is important to wipe the surface dry afterwards to avoid leaving any moisture.
For those with lacquered surfaces: fingerprints can be effectively removed with a microfiber cloth without dulling the finish.
