ᐅ How can IKEA Brimnes furniture be modified or customized as a DIY project?
Created on: 12 Sep 2021 08:37
riteo50
riteo50
12 Sep 2021 08:37
Hello everyone, I am currently exploring how to customize IKEA Brimnes furniture in a DIY style. Specifically, I’m interested in ways to enhance these often quite simple pieces both functionally and visually, without having to buy completely new furniture. I’m looking at everything from simple modifications like new handles or paint jobs to more complex alterations, such as integrating lighting, adding extra storage solutions, or making structural changes like cutting out fronts or combining multiple modules. If anyone has experience or tips specifically for the Brimnes range—whether regarding material quality, customization possibilities, or common tricks—I would really appreciate your input. What worked well for you, and where did you encounter challenges? Also, which tools and materials proved useful? Thanks in advance for your feedback!
Lisele
12 Sep 2021 09:21
riteo50 schrieb:
I’m interested in both simple modifications like new handles or repainting, as well as more complex renovations, for example integrating lighting, adding extra storage solutions, or structural changes such as cutting out front panels or combining several modules.
I can totally relate to that – Brimnes is really practical but still a bit plain in its standard form. I’ve actually sanded down the drawer fronts of my Brimnes dressers and repainted them with chalk paint, which made a huge difference. You do have to make sure the surface is quite smooth so the paint adheres properly. I was a bit nervous about cutting out the fronts myself because particleboard tends to chip easily. I recommend using templates and working slowly with a router.
When it comes to lighting, I especially like attaching LED strips inside the shelves or the interior of the cabinets. It creates a nice effect and improves visibility. With Brimnes, it’s important to know that the back panels are often made from thin material, so you need to be careful when drilling or gluing to avoid damage.
I would suggest starting with smaller modifications and carefully planning the bigger changes, especially if you want to combine several modules.
glamo
13 Sep 2021 17:45
Lisele schrieb:
To be honest, I was a bit nervous about cutting the fronts because particleboard tends to chip easily.
That’s exactly one of the biggest challenges when modifying Brimnes furniture. Using MDF or particleboard covered with plastic foil is cost-effective but not ideal for detailed woodworking. If you want to cut fronts or create openings, I highly recommend using a fine-toothed saw or a router with a smooth cutting bit.
Furthermore, I find the modular components well-suited for assembling larger pieces of furniture. Here is my step-by-step guide, which has worked well in my DIY projects:
- Planning: Carefully sketch which modules you want to combine and what functions they should have.
- Disassembly: Take the parts apart carefully to make modifications easier.
- Surface Preparation: Sand any edges as needed and apply primer if you plan to paint.
- Connections: Use wooden dowels or sturdy screws to securely join the modules.
- Additional Features: For integrating LED lighting, I recommend plastic cable conduits to keep the appearance tidy.
Personally, I often install metal brackets inside for extra stability—especially when the furniture carries more weight or becomes larger through modification. Do you have specific projects in mind with Brimnes?
riteo50
14 Sep 2021 10:12
glamo schrieb:
Do you have any specific projects in mind with Brimnes?
Yes, thanks for the detailed information, that’s already very helpful. Specifically, I plan to place several Brimnes dressers side by side and connect them across to create a longer sideboard. In doing so, I would like to:
- Keep the drawers usable separately but remove the visual separation by using a continuous frame profile.
- Integrate LED lighting into the top edge, preferably with a dimmer.
- Finish the surfaces with a matte, colored paint instead of white.
I’m especially concerned about connecting the dressers, since there are no parts designed for that purpose. It would be interesting to know whether special screws or fittings should be used to ensure both high stability and the possibility of separating the furniture again later. What do you think is the best way to achieve this? Regarding the lighting, I like that several people have already suggested installing LED strips on the inside walls – how do you best attach them so they hold securely and keep the cables hidden?
O
olivernu
14 Sep 2021 12:58
riteo50 schrieb:
I’m especially concerned about connecting the dressers because there are no specific components designed for that purpose. It would be useful to know whether using special screws or fittings would be recommended to ensure high stability while also allowing the furniture to be separated later if needed.
For your project, I recommend using folding connectors or so-called corner brackets made of metal, which you can attach from the inside on the sides of the dressers. These offer more flexibility because they are easy to screw in and also to remove later. Alternatively, flat connectors can be suitable, which are sometimes used for modular furniture connections. Make sure to choose screws of an appropriate length to avoid the panels tearing out on the material side.
Regarding the LED installation:
- Use self-adhesive LED strips with a silicone coating, as they provide good adhesion and are somewhat water-resistant.
- For neat cable management, I recommend slim cable ducts that you can attach inside on edges or back panels.
- If you want to use a dimmer, ensure it’s compatible with your LEDs and preferably remote-controlled for convenient operation.
It is important to sand the surface properly before painting and to treat it with a suitable primer; otherwise, the paint may peel. It’s worth investing in quality products here to ensure the paint lasts a long time.
