ᐅ How can I visually customize IKEA Platsa furniture?
Created on: 28 Jun 2015 08:37
U
Ulineo
U
Ulineo
28 Jun 2015 08:37
I am currently exploring ways to visually customize IKEA Platsa furniture to adapt the rather simple base units to a personal style. Since the basic construction of the Platsa series is quite modular and straightforward, I believe there could be many opportunities to enhance its appearance or completely reinterpret it.
I am particularly interested in options that go beyond simple decoration or storage, such as altering surfaces, introducing colors, textures, or other materials. Practical tips on suitable paint finishes, wallpaper, lighting, or changing handles would also be helpful.
What have you tried or would you recommend if you want to maintain functionality while creating a unique design? Are there any niche solutions or minor modifications that give the furniture a distinctive look?
I look forward to your experiences and suggestions!
temeli
28 Jun 2015 11:53
Ulineo schrieb:
I’m especially interested in ideas that go beyond simple decoration or storage, such as altering surfaces, adding colors, textures, or other materials.
That’s exactly where I come in! The Platsa furniture is so versatile and offers a great base for artworks in the living room or studio!
For example, I redesigned the fronts with waterproof chalk paint – it creates a really nice vintage effect! Then, I lined some compartments with wallpaper patterns that become visible when you open them – a great detail that immediately catches the eye.
I would also recommend swapping out old handles for unique ones made of wood or metal. That makes an instant difference!
And: you can also install LEDs inside, which looks modern and turns the furniture into a highlight at dusk.
Just give it a try, it’s a lot of fun! 🙂
benonon
29 Jun 2015 15:22
temeli schrieb:
For example, I redesigned the fronts using waterproof chalk paint – it creates a really nice vintage effect!
This is indeed a popular method, as Platsa fronts are made from MDF panels with a melamine-coated surface, which can be sanded and primed quite well. I recommend starting with a fine sanding sponge (grit 220 or finer) to slightly roughen the surface so the paint adheres better.
Afterwards, you should apply a primer (bonding primer) specifically designed for melamine to prevent the paint from peeling. With chalk paint or water-based acrylic paint, seal the surface afterwards with a matte clear coat to ensure the furniture withstands everyday use.
For textures, veneer sheets or self-adhesive decorative films in wood, stone, or metal look are also suitable. These can be cut precisely and applied neatly, though cutting accurately around corners and edges can be a bit challenging.
If you are using LED lighting, make sure that cables and power supplies are well hidden and protected against overheating. Warm white LEDs are recommended for pleasant lighting and should be dimmable if possible.
One more question: Which color scheme or style do you prefer? Minimalist, farmhouse, industrial? That will significantly influence your choice of materials and colors.
GLORIA
1 Jul 2015 09:41
benonon schrieb:
One more question: Which color scheme or style do you prefer? Minimalist, country house, industrial? That significantly influences your choice of materials and colors.
Based on that, I would suggest approaching the renovation with the following structure:
- First, clearly define the target aesthetic to guide the later selection of colors and materials.
- Check which parts of the furniture system actually need to be changed (front panels, sides, interior components).
- For painting, always use high-quality primer and sealant to ensure durability.
- For textile or wallpaper-like inserts, create perfectly cut overlay panels to personalize the compartments inside without altering the furniture structure.
- Replace handles with high-quality, ergonomic versions – this adds value and improves the tactile experience.
- Plan and conceal power outlets efficiently for lighting purposes.
Especially important: Throughout all changes, the modular functionality should remain intact so that the furniture stays flexible.
This systematic approach helps both beginners and professionals to plan and execute the renovation effectively.
