ᐅ How can I use Ikea Platsa furniture as a room divider?
Created on: 26 Oct 2022 09:17
chasepar
chasepar
26 Oct 2022 09:17
I am currently considering how to best use my Ikea Platsa furniture as a room divider. My main focus is on arranging the modules in a way that not only visually separates the space effectively but also provides storage. It is important to me that the construction is stable enough and can be flexibly adapted to different room layouts. Does anyone have tips on assembly, possibly on fastening the elements together, or ideas for back panels? Suggestions on how to aesthetically use the Platsa modules as a partition wall are also very welcome. Thank you in advance!
BOSULE
26 Oct 2022 11:03
Hello chasepar,
your question is well thought out and clearly formulated, which makes the advice easier. For using Platsa as a room divider, I recommend the following points:
- Use the larger modules to create a stable base.
- Connect the individual units with the included IKEA connecting fittings to prevent shifting.
- Back panels are important for stability; if the original Platsa back panels are not sufficient, you can attach a thin MDF board secured with clamp profiles or screws.
- To visually separate the furniture, you can combine different colors for the doors or use open shelves.
- Pay attention to the weight, especially if you set up tall cabinets as a room divider.
This kind of solution creates a flexible, functional room divider with storage that can adapt to changing room sizes.
retau
26 Oct 2022 14:29
Hey chasepar!
Platsa is great for room dividers! I’ve used it myself to separate my living room and I love the result! 😊
Here are some tips I can recommend:
- Position the units with open compartments facing the room to keep the space feeling light.
- Use various decorative items on the shelves to create a cozy atmosphere.
- If you have children, secure the units to the ceiling or wall for added safety.
- You can also incorporate plant pots or small lights to bring the dividing furniture to life.
Don’t be afraid to get creative! Good luck, you’ve got this!
lalutau
27 Oct 2022 08:42
The mentioned points are clear and practical. Additionally, I suggest measuring the exact room dimensions and door openings before construction to optimally adapt the modules. The rectangular shape of the Platsa elements allows flexible alignment, but the hollow sections should be reinforced, especially when used freestanding as a room divider. Additional bracing at the back can be used for this purpose.
The subfloor should not be overlooked either: on carpet, the setup might feel unstable. If it is a rental apartment, make sure to use fastening methods that leave no residue.
One last tip: using closed doors on the room side improves the appearance and reduces visibility through the divider, which is important for a room partition.
SUFOJE
27 Oct 2022 15:56
retau schrieb:
You can also integrate plant pots or small lights to bring the dividing furniture to life.
Good point! To make the partition with Platsa truly functional and cozy, it’s worth keeping a few things in mind:
- The arrangement of the modules should not completely block the light, as Platsa mainly consists of closed elements.
- Open shelving units help keep the space feeling airy while providing storage for books or decorations.
- Electrical wiring for indirect lighting can be routed inside the modules, creating a pleasant ambiance.
- When securing the modules, make sure they are firmly fixed to each other or to adjacent walls to prevent tipping.
I hope these tips are helpful to you.
