ᐅ How can I use Ikea BESTA as a shoe storage unit in small entryways?
Created on: 23 Dec 2022 19:37
Sauviniciu
Sauviniciu
23 Dec 2022 19:37
I’m planning to use an Ikea Besta unit as a shoe rack in my very small entrance area, as I want to make the best use of the available space. The dimensions are quite limited, approximately 90 cm (35 inches) wide and a maximum depth of 40 cm (16 inches). It is especially important to me that several pairs of shoes can be stored neatly and still be easily accessible, without the unit appearing too bulky or unnecessarily blocking the entrance area.
My question to the community: Which BESTA modules or combinations work best as shoe storage in small entrance spaces? Are there clever interior fittings or additions you would recommend to store shoes efficiently without wasting space? I’m also open to ideas on how to make the unit both visually appealing and practical, possibly with doors, drawers, or special inserts.
Thanks in advance for your tips and experiences!
pikin
23 Dec 2022 20:28
A Practical Approach:
For small entryways, the combination of low, shallow modules from Ikea BESTA (e.g., 60x40 cm [24x16 inches] or 90x40 cm [35x16 inches]) is particularly recommended, as they make use of the limited depth without taking up too much width.
TIPS:
- Use internal drawers or adjustable shelves to customize the compartment heights exactly to the size of the shoes. This helps avoid unnecessary empty space.
- Doors are a good option to keep the entryway looking tidy; as an alternative, folding doors are also suitable, as they require less forward clearance.
- For smaller shoes (sneakers, ballet flats), narrow pull-out shelves that allow for multiple rows stacked vertically are practical.
- If possible, use a version with drawers or boxes beneath the shelves to also provide space for seasonal shoes or accessories.
Conclusion: The right choice of modules plus flexible layout is crucial. Since the BESTA frame is modular, it’s easy to experiment and adapt it to individual shoe sizes and the number of pairs.
Palenar
24 Dec 2022 08:46
pikin schrieb:
For small entryways, the best option from Ikea BESTA is mainly the combination of low, shallow units (e.g., 60x40 cm (24x16 inches) or 90x40 cm (36x16 inches)) because they make use of the limited depth without taking up too much width.
I fully agree, but I’d like to add some technical details that are often overlooked when using BESTA as a shoe rack in small hallways:
1. Material choice and stability: BESTA shelves typically use 15 mm (0.6 inch) thick panels. Since shoes can weigh between 500 g and 1.5 kg (1.1 to 3.3 lbs), and vacuum cleaners or other hallway items are sometimes placed on or next to the unit, it is advisable to reinforce the shelves (for example, with additional support strips) to prevent sagging.
2. Ventilation: Because shoes can occasionally be damp, it is recommended to have at least small ventilation gaps or holes in the back or side panels to avoid odors. This is especially important with closed doors.
3. Interior layout: Adjustable shelves are essential because this allows you to customize the height—whether for boots (about 30 cm (12 inches) clearance) or flat shoes (15–20 cm (6–8 inches)). I recommend measuring precisely in advance with a tape measure. It’s also helpful to classify different shoe types and plan corresponding shelf heights accordingly.
4. Doors and opening mechanism: Since small entryways have limited space for door swings, sliding doors in BESTA are worth considering. Alternatively, fold-up doors with soft-close mechanisms can prevent accidental bumps.
Could you please provide details about your existing ceiling height and the number of shoes per category (boots, sneakers, children’s shoes, etc.)? This would help to offer more tailored recommendations.
Sauviniciu
25 Dec 2022 10:03
Palenar schrieb:
Could you please provide more details about your current ceiling height and the number of shoes per category (boots, sneakers, children’s shoes, etc.)?
Thank you for the detailed analysis, Palenar. My ceiling height is approximately 200 cm (79 inches), but I want to keep the height of the BESTA shelf to a maximum of 100 cm (39 inches), so it doesn’t appear too dominant and could potentially be used as a seating area (with a cushioned cover).
The current number of shoes includes:
- 4 pairs of adult sneakers (about 14–17 cm / 6–7 inches high)
- 3 pairs of flat shoes (ballet flats, loafers, about 10–12 cm / 4–5 inches high)
- 2 pairs of boots (up to 30 cm / 12 inches high, not full-length shaft)
- 1 pair of children’s shoes (about 12 cm / 5 inches high)
I’m considering dividing the shelf into two to three horizontal levels and possibly adding drawer solutions for smaller items. Doors would be a good idea to keep the entrance area tidy.
My focus is on a functional layout, storage space for the shoes listed above, and clever use of the approximately 40 cm (16 inches) shelf depth.
If anyone has ideas for incorporating a seating function or how to visually integrate this with the rest of the entrance area, I would appreciate the suggestions.
