ᐅ How can I sustainably and environmentally responsibly modify or repair IKEA BESTA furniture?
Created on: 19 Jul 2020 09:27
ruegmont39R
ruegmont3919 Jul 2020 09:27Hello everyone, I would like to sustainably and environmentally responsibly modify or possibly repair my IKEA Besta shelving unit to extend its lifespan and reduce resource consumption. I am particularly interested in which materials or techniques are effective for producing as little new waste as possible, reusing existing components, and keeping the carbon footprint low. Are there established methods, sustainably produced replacement parts, or ways to preserve screws and joints so that the modification is as reversible as possible? How do you handle situations where, for example, a surface is damaged or a part is no longer stable enough? I look forward to your expert advice and would like to learn concrete suggestions on how to sensibly upgrade the Besta without having to completely replace or discard it.
Your question about a sustainable renovation of the BESTA is basically valid, but I want to emphasize that many IKEA furniture pieces use materials (chipboard, melamine) that inherently have a limited lifespan, which is difficult to extend.
It would be helpful to clearly define which parts you want to keep. Floors and side panels can be treated with special wood oil or wax to protect the surface. However, you should avoid complete disassembly because chipboard often gets damaged when taken apart.
If the surface is damaged, repair small scratches with wood filler or special repair pens. If you want to change the color of the furniture piece, water-based paints or eco-friendly coatings with low emissions are suitable.
Regarding stability: Reinforcements with metal brackets on the inside can increase the lifespan without affecting the appearance. Screws that sometimes loosen can be secured with some wood glue or small wood chips inside the holes to ensure they hold again.
I fundamentally question how far one wants to stretch the term "sustainable" when mainly relying on industrially produced materials designed only for short-term use. For me, sustainability begins with choosing durable base materials – but unfortunately, IKEA sees it differently.
ruegmont39 schrieb:
I am especially interested in which materials or techniques make sense here to produce as little new waste as possible, continue using the existing components, and keep the carbon footprint low.
As an addition: If you want to remodel the BESTA sustainably, I recommend focusing primarily on reusable and locally sourced materials. For example, you can replace damaged fronts with veneered wood panels, which are much easier to work with than particleboard.
Building on that, you can protect the surface with eco-friendly linseed oil–based varnishes or waxes.
For stabilization, screws with a small diameter made of stainless steel are also suitable – they are durable and less prone to rust. If necessary, you can hide them in the back panel or legs.
As a general rule: avoid unnecessary replacement of entire components. Instead, repair spots as needed and improvise by using individual parts for new functions, such as shelves or removable boxes. Converting to an open shelving unit with recycled fabric as the back panel instead of particleboard can also reduce the ecological footprint.
In addition to the previous discussion, I would like to present some facts regarding the sustainability of IKEA BESTA. A fundamental limitation is that the basic construction consists largely of particleboard made from wood residues and synthetic resin. This significantly limits recyclability and durability.
- Ideally, the load should be distributed evenly, with no overloading, as particleboard tends to swell when exposed to moisture or excessive weight.
- Instead of completely replacing the fronts, they can be sanded and sealed with low-toxicity hardener varnishes or natural oils that preserve the material’s breathability.
- For connections, chrome-plated or stainless steel fittings are ideal because they are corrosion-resistant and therefore last longer.
- Damage to edges can be repaired using wood strips (preferably FSC-certified) to prevent further moisture damage.
Before making modifications, I recommend ensuring that stability is not compromised. Original screw holes are often damaged by frequent screwing and unscrewing and may need to be filled with wood glue and wooden dowels or a wood chip glue mixture to provide new strength.
In general, the approach of keeping the furniture in use for as long as possible with targeted repairs is more sustainable than a complete overhaul with replacement parts, which may consume additional resources.
