ᐅ How can I speed up the assembly of an Ikea PAX wardrobe?
Created on: 12 Nov 2021 08:37
Dinaon
Hello everyone, I recently purchased the Ikea Pax wardrobe and am now about to start assembling it. Since I want to keep the assembly time as short as possible, I’m interested in any strategies or tips you can recommend to make the process as efficient and quick as possible. I’m looking for both organizational advice, such as assembling in teams or specific preparation steps, as well as technical tricks that make the assembly easier or faster. Does anyone have experience with tools, sequences, or other aids that significantly speed up the process? Thanks in advance!
bapar
13 Nov 2021 07:14
Dinaon schrieb:
I’m interested in both organizational tips, such as team setup or specific preparation steps, as well as technical tricks that make assembling easier or faster.
Regarding this point, I would like to add that when working in a team, it is essential to have clear responsibilities and communication channels. While one person prepares the side panels, another can handle the back panel, and a third can join the individual modules. This prevents bottlenecks and keeps the work synchronized. It is important to carefully check for millimeter (inch) deviations during mutual inspections, as these can cause fitting issues later with such large pieces of furniture. Have you already decided whether you will assemble the pax alone or with several helpers? That could make the recommendation more precise.
Gregory
13 Nov 2021 08:42
To optimize the assembly process, I also recommend downloading the manual digitally in advance and keeping it open on a large screen. This way, you don’t have to constantly search through the printed booklet. Additionally, organizing the screws by type and size in small bowls is helpful. Having a second set of common tools ready also saves trips back and forth. When installing the drawer slides, it is advisable to use a spirit level to ensure everything fits precisely and no rework is needed.
Lidan56
13 Nov 2021 09:15
Important: Take your time with the back panels. They don’t always fit correctly right away, and rushing their installation can end up costing additional time. It’s better to work carefully and patiently.
bapar
14 Nov 2021 08:03
Gregory schrieb:
When installing drawer slides, it is recommended to use a spirit level to ensure everything fits perfectly and to avoid rework.
This is an important point! Especially with Pax, the drawer components are very sensitive to misalignment. Using a spirit level saves time and frustration when fitting the drawers later on. Additionally, the slides should be installed with gentle pressure to avoid damage. Another time-consuming issue is retightening the screws – it’s best to initially tighten all screws lightly and then finish by tightening them to the recommended torque with a torque wrench or cordless screwdriver.
