ᐅ How can I securely mount Ikea Metod kitchen cabinets on walls in older buildings?
Created on: 14 Apr 2024 08:37
MATYS7I am planning to install an Ikea Metod kitchen cabinet line on the walls of my older building. The walls are old, partly uneven, and mostly consist of load-bearing masonry with plaster, with some areas covered in wood paneling. My question is: How can I securely and permanently mount the Metod kitchen cabinets on such older walls? What should I specifically pay attention to when fastening (e.g., wall condition, appropriate anchors or screws, load distribution), and which materials or methods are recommended to avoid damage to the walls while ensuring a stable installation? I would also like to know how to compensate for unevenness, as the walls are not perfectly flat. Any helpful experiences or detailed tips would be greatly appreciated.
Hello MATYS7, your question is very well thought out and shows that you are seriously considering the issue. When installing Ikea Metod kitchen cabinets on older walls, the following points are particularly important:
- First, you should carefully assess the wall type. Is it solid masonry or lightweight construction with wood paneling? For solid masonry, use hammer-in anchors or chemical anchors depending on how much load the cabinets will carry.
- If the wall is uneven, you can use mounting brackets with adjustable spacing or place shims made of wood wedges or special leveling plates underneath to ensure the cabinets are mounted perfectly vertical and stable.
- It is important to distribute the load evenly. Ikea Metod cabinets are usually attached to a sturdy support rail (for example, an additional wooden batten properly anchored), so you don’t have to fix each cabinet attachment individually to the wall.
- Screws and anchors must be chosen appropriately for the wall material: heavy-duty anchors for brick or concrete walls, screws directly into wood panels.
- Always check the load-bearing capacity of the wall, especially since older plaster can be crumbly in some areas.
Summary:
1. Identify the wall type
2. Select suitable anchors/screws
3. Use mounting rails as supports if needed
4. Compensate for unevenness with shims or plates
5. Pay attention to load distribution
If you like, I can also provide you with a list of specific products.
Summary:
Nathanaelk15 Apr 2024 13:06Hello everyone, I like to go into detail here because secure installation in old building walls is generally a challenge. First of all, MATYS7, you should know the physical properties of your wall – masonry can be made of brick, calcium silicate, or even tuff, all of which require different types of anchors.
If you have cavities or loose plaster areas, for example, this can make anchoring more difficult. For solid walls, heavy-duty anchors or chemical injection mortar (epoxy resin) with threaded rods are ideal. In this process, a drill hole is first cleaned, the adhesive is injected, and then the bolt is inserted – this achieves very high load capacities, which are ideal for heavy kitchen cabinets.
An important point is load distribution: Metod kitchens are often bulky and are statically highly loaded, especially under the wall cabinets. Therefore, I always recommend installing a continuous mounting or support rail made of wood (or metal), which you anchor at multiple points. The cabinets then hang on this rail, which evenly distributes the loads to the wall.
Regarding your uneven surfaces: Depending on the extent, you can either use leveling screws or washers offered by the manufacturer, or make the mounting rail adjustable – for example, with spacer blocks. This ensures that the cabinets hang straight and no tension is created on the wall.
Last but not least: Use drill machines with a hammer function for masonry, but not for wood paneling, as they could otherwise be damaged. When drilling into old building studs, be careful not to hit any pipes or cables – so always check in advance.
Are there any details about your wall that we should discuss further?
I completely understand how important kitchen safety is to you, especially in an older building! I once had the problem that my old wall was somewhat crumbly, and with regular anchors I couldn’t achieve real stability.
Sometimes you really feel unsure whether everything will hold or if the cabinet might fall down when fully loaded. What helped me was mounting the cabinets on a solid wooden battens that was securely anchored to the wall. This way, the weight is distributed much better.
I also found it very important to work slowly and patiently – it’s better to use two more anchors than one too few. For uneven surfaces, I used wooden wedges, which can be finely adjusted and are almost invisible once installed.
I want to emphasize this again: uneven walls are quite common in older buildings. Don’t be discouraged!
It might help to make a sketch showing where the cabinets will hang and where the wall is most stable. If you still have doubts, it’s better to seek professional help for drilling, especially with older walls or if there are pipe or wiring systems inside.
LOGEMIN schrieb:
If the wall is uneven, you can use mounting brackets with adjustable distances or place shims in the form of wooden wedges or special leveling plates underneath
Just as an addition and a critical point to consider: I find that it is often assumed that typical older building wall structures are solid enough to safely support the heavy Metod kitchen cabinets. However, this is not necessarily the case.
For me, the key question is whether, for example, there is wood paneling on a batten framework or even a lightweight construction. In such cases, I would not use conventional wall plugs (anchors) in the wood and then expect a high load capacity. A proper structural assessment is definitely essential here.
This is a central point, but you must check the load-bearing capacity of these anchoring points and, if in doubt, consider reinforcing the wall construction (e.g., additional studs and sheathing).
Make sure to measure the loads involved: The wall cabinets fully loaded plus dynamic forces from opening and closing can exert significant stress.
I also see the plaster as critical: It may not hold wall plugs and could break out. Therefore, before installation, remove any loose plaster layers if necessary and recondition the wall; otherwise, you may experience holes and cracks later on.
Can MATYS7 provide more detailed information about the wall construction? Then advice can be more specific.
Nathanaelk schrieb:
That’s why I always recommend installing a continuous mounting or support rail made of wood (or metal), anchored at multiple points.
