ᐅ How can I securely and safely attach Billy bookcases to walls in older buildings?
Created on: 18 Jan 2021 08:37
plo31
plo31
18 Jan 2021 08:37
I am facing the challenge of securely and stably fixing my Billy shelves to the walls in my older apartment. Since the walls here often do not have a continuous solid structure, but partly consist of thin plaster on masonry or stud walls, I have a few questions:
Which fastening methods and materials are best suited to reliably prevent the shelves from tipping over or falling? Are there special anchors or plugs that work better in older walls than standard expansion anchors?
What should I do if I encounter cavities or if the wall seems quite crumbly?
I would appreciate any professional advice, as I want to keep the shelves stable in the long term without causing unnecessary damage to the walls.
Thank you in advance!
gadalu
18 Jan 2021 09:14
when attaching Billy shelves to walls in older buildings, the primary factor is the wall material. Older walls are often either solid (brick or natural stone) with plaster or consist of timber frame or lightweight construction walls.
1. For masonry, I recommend heavy-duty anchors of appropriate length, such as metal expansion anchors or toggle anchors. These provide significantly better hold than simple plastic anchors.
2. With brittle plaster, you should first identify the load-bearing layer and possibly install a backing board. If there are cavities, use cavity anchors with claw fasteners or metal anchors.
3. For timber stud walls, always screw directly into the wooden studs, not just into the drywall or panels.
It is also very important to always secure the shelves with the included wall brackets. Alternatively, additional screws on side angles into load-bearing elements can help.
A quick check with a magnet can help locate reinforcements or metal anchors, which can sometimes be utilized in older buildings.
Overall, I recommend carefully probing the wall with a screwdriver or drill before installation and then selecting the appropriate anchors and screws.
Tause
18 Jan 2021 10:25
gadalu schrieb:
Older building walls are often either solid (brick or natural stone) with plaster or constructed as timber frame or lightweight walls.
This is an important point, but I would add that it is essential to pay close attention to the wall’s moisture, especially in older buildings. Damp walls can significantly reduce the holding strength of anchors.
Additionally, the long-term load profile is a key consideration: How much weight will the shelves need to support? Since Billy shelves are designed for heavy loads, even high-quality anchors can fail if the load is not properly distributed.
gadalu schrieb:
Always secure shelves with the supplied wall bracket
While that is standard advice, I have often experienced that the screws included are completely unsuitable for older walls. In such cases, it is advisable to invest in heavy-duty anchors, such as chemical anchors or bolt anchors, if the wall material permits.
My recommendation: To be safe, first test the wall structure with a small drill hole and then choose the appropriate anchors accordingly. Sometimes there is meterwerk (lath and plaster) underneath, which requires different anchors; if it’s a hollow cavity, then other types are needed.
V
vin_leo
18 Jan 2021 11:46
Hi everyone! 🙂
From my own experience, stabilizing Billy bookshelves in older buildings is always a bit of a challenge, but definitely doable!
My tip: If you want to be really sure, get metal hollow wall anchors or special support plates that you install behind the plaster. This increases the bearing surface and makes the mounting more secure.
plo31 schrieb:
Which fastening methods and materials are best suited to reliably prevent shelves from tipping over or falling?
I attached my shelves using brackets at the top on studs or wooden beams, which I located with a small drill bit. It works really well if you take some time. Another tip: always use at least two fixing points per shelf, or even three if possible.
Sometimes it also helps to screw a plywood board behind the shelf onto the wall and then attach the shelf to that. This spreads the load better and makes the whole setup really solid.
Good luck, it’ll work out! 🙂
tolokau
19 Jan 2021 14:11
Hello plo31,
I would like to add a brief step-by-step guide on how to securely mount Billy shelves on older walls:
1. Determine the wall type: Use the smallest drill bit and drill a test hole. Based on the drill dust and resistance, you can identify whether you are drilling into solid brickwork, a cavity wall, or timber.
2. Choose the appropriate anchors:
- Solid wall: metal expansion anchors (toggle anchors) suitable for screws up to 8 mm;
- Cavity wall: metal cavity anchors with expanding claws;
- Timber studs: use wood screws directly, no anchors needed.
3. Load distribution: Position mounting points preferably on supporting beams or studs; if necessary, use wall hooks or brackets.
4. Attach wall hooks: Use at least two per shelf unit to prevent tipping.
5. Additional reinforcement: For crumbly plaster, first install a substructure made of wooden battens.
6. Check screws and anchors before applying load: After mounting, briefly test to ensure the shelf is firmly fixed and does not shift.
Common mistakes:
- Not checking the wall structure
- Using the wrong type of anchors
- Too few fixing points
Regarding how to proceed with cavities or crumbling walls: options like chemical anchors or large-surface reinforcements are possible but often involve more effort.
Good luck!
gadalu
20 Jan 2021 07:59
tolokau schrieb:
Typical mistakes
I completely agree. One often overlooked aspect is the quality of the screws. Especially for metal or wood screws, it’s important to use stainless steel or galvanized ones to prevent corrosion.
Furthermore, I would add that in particularly brittle older structures, using heavy-duty anchors or even consulting a specialist is advisable to avoid structural damage.
I also notice the issue that some users only focus on fixing the shelf to the wall but should also reinforce the shelf itself, especially when storing heavy loads.
In short: accurately identifying the wall material, choosing the appropriate anchors, and proper installation ensure long-term stability.
