Hello everyone, I am currently planning to install an IKEA Metod kitchen and am facing the decision of how to further finish the countertops myself to improve both their appearance and functionality. Specifically, I am interested in which methods and tools you use to sand, seal, or paint the countertops without damaging the surface. Are there established techniques that work well with melamine or plastic coatings? Or is it better to sand certain areas first and then treat them with a special paint? Additionally, I would like to know how to make the edges significantly more resistant to water and impact. Do you have any tips on products that work well without compromising the look? I look forward to your experiences, thanks in advance!
Hi arminbar, great that you’re taking on the refinishing of your Metod countertop! 😄 I had the same issue once – my countertop looked a bit sterile right after installation. My advice: start by gently sanding the surface with fine sandpaper (grit 220 or finer), being careful not to damage the plastic coating. Then, apply a thin layer of high-quality acrylic or polyurethane varnish, which works really well on melamine surfaces. Be patient, let each layer dry thoroughly, and sand lightly between coats – this will make it very durable. For the edges, I used flexible PVC edge trim, which protects against water and impacts, and also looks quite nice. This way, the appearance stays fresh, and the countertop lasts longer. Good luck, you can do it!
I think it’s great that you’re paying such close attention to the finishing of the countertops! The edges can also be a concern for me with my Metod kitchen because moisture can easily seep in. In my experience, the best approach is to carefully seal the edges with a waterproof sealant before installation—such as a clear silicone or acrylic adhesive suitable for sealing cut edges. I was uncertain about this for a long time myself, but now it gives me peace of mind because moisture doesn’t get under the surface. If you decide to paint, make sure to sand and clean all edges beforehand, as the finish won’t adhere well otherwise. I’m keeping my fingers crossed that these tips work out well for you!
For refinishing IKEA Metod countertops, a systematic approach is recommended: First, identify the type of surface (melamine-coated, plastic, wood decor) as this influences the choice of refinishing method. For melamine surfaces, fine sandpaper (grit 220-320) is suitable for gently smoothing out any unevenness. Afterwards, use specific sealing varnishes based on plastic that do not peel. For edges, edge protection profiles made of PVC or aluminum should be applied to prevent mechanical damage and moisture absorption. Alternatively, epoxy resin can be used, which is waterproof but requires careful application. I also recommend testing the treatment on an inconspicuous area beforehand to check compatibility. Tools: sandpaper, brushes for varnishes or spray equipment, edge protectors, and suitable sealant. A general procedure: - Lightly sand and clean the surface - Apply varnish in thin layers - Seal the edges - Final check with moisture protection. This way, you avoid damage and increase durability.
Hey arminbar, I think it’s great that you want to tackle this yourself! 😊 For my countertop, I treated the edges with a special wood varnish that is water-resistant. I carefully sanded it first, then applied several thin layers. It really holds up well and looks great afterward! If you like, you can also apply hard wax oil as a finishing touch; it makes the surface very durable and gives a nice shine. Just apply it and wipe off any excess oil after one to two hours. Personally, I avoided sanding the surfaces completely, because that would remove the protective layer and increase the risk of swelling. Good luck with your project!
Hello arminbar, I completely understand you, the finishing process is an important step to ensure you enjoy your countertop for a long time! What I can recommend is using fine sandpaper (at least 240 grit) for the surfaces. For sealing, I used a high-quality polyurethane lacquer system that is specifically designed for furniture surfaces. It is important to apply very thin layers and lightly sand between each coat. This way, you achieve a truly hard and durable surface. Otherwise, I would definitely avoid using coarser sandpaper, as it can ruin the surface! For the edges, I bought matching trim pieces and fixed them with clear assembly adhesive. This also protects the countertop from dust and moisture. I really feel comfortable in my kitchen now!
