ᐅ How can I quickly and easily repair BILLY shelves?
Created on: 21 Feb 2024 08:17
Daryl67
Hello everyone, I bought several Billy shelves from IKEA to neatly store my books and various items. Unfortunately, I’ve noticed some common weaknesses in several of these shelves: warped or broken shelves, loose joints, and partially bent back panels. My question to you is: How can I quickly and easily repair BILLY shelves without having to buy completely new shelves or entire units? Are there any simple tricks or proven methods to effectively fix these everyday damages in the furniture in a cost-effective way and with reasonable effort? I would appreciate concrete tips and experiences that can be done without professional tools or too much effort.
Daryl67
23 Feb 2024 09:02
Jensson schrieb:
There are special narrow brackets with elongated holes that allow flexible positioning and prevent stress in the structure when the wood expands or contracts.
That’s a very helpful tip, thanks! One more question: Where is the best place to order these brackets? Is there a specific name or manufacturer you would recommend?
Also, I wanted to mention that I hesitated to disassemble the shelves beforehand – is it possible to install reinforcement without having to remove the shelves?
Nathanaelk
23 Feb 2024 10:23
Daryl67 schrieb:
One more question: Where is the best place to order these brackets? Is there a specific term or manufacturer you would recommend?
Hello Daryl67,
For metal brackets, I recommend using ones made of galvanized steel or powder-coated steel to prevent corrosion. They are usually referred to as "furniture brackets with elongated holes" or "adjustable cabinet brackets."
Sources: Home improvement stores like Obi, Hornbach, Toom, or online retailers such as Amazon or eBay offer a wide selection.
Whether you can install the reinforcement without removing the shelves depends on your shelf dimensions. In most cases, it is possible but impractical, since BILLY shelves are usually inserted from above. For the best results, I still recommend removing the shelves to work.
If that is not possible, you should carefully support the unit and ensure there is enough space for tools and brackets.
